Question about Hobart H600 Stand Mixer
Podrias darme una diagrama electrico de la batidora hobart hl600
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Posted on Nov 15, 2007
  • 5 Answers
SOURCE: quisiera saber las instrucciones de uso de esta
Aqui tens instrucciones em ingles
Instructions in english
http://www.vittitow.com/images/hobarta200.pdf
Posted on Mar 02, 2010
KevinWhite
  • 1902 Answers
SOURCE: trouble code for hobart HL600
Hello & Welcome to FixYa
Please get back to me with a detailed question about your Hobart as the question is still unclear because trouble code is not written.
Kevin
Posted on Jul 15, 2011
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
Aug 19, 2015 | Hobart Food Mixers
HOW CAN I GET THE WIRING DIAGRAM FOR HL600 HOBART MIXER
Take a look at:
http://www.diversewebsitesolutions.com.au/hf/manuals/FOOD%20PREP/MIXERS/CURRENT%202011%20MIXERS/HOBART%20HL600/HOBART%20HL600%20MIXER%20TECHNICAL%20AND%20SERVICE%20INFORMATION/
Oct 07, 2014 | Hobart Food Mixers
Como desarmar
primero desmonta el motor de la base. luego en el motor hay tres tornillos en la parte donde entra el cable de alimentacion, quitalos. luego en el cabezal movil quitas un tornillo allen 4mm, en el vastago donde se acoplan los accesorios debes quitar una chabeta y el pin de seguridad y luego halas toda la pieza y abras quitado la tapadera de los engranajes. espero te sirva de algo la respuesta
Sep 21, 2013 | Hamilton Beach 63221 Stand Mixer
Tengo una batidora y ya le cambie los carbones y no me funciona que puede ser
Hola LALOB_RO. Cuando cambió los cepillos (carbones), es posible que haya instalado uno o ambos de ellos para que los cepillos no encaja correctamente. Sólo hay un camino para que los cepillos que se ha instalado correctamente. La caracóncava del cepillo debe descansar por completo en el conmutador de la armadura. Siusted lo ha girado 90 grados demasiado, el cepillo no se asienta correctamente y elmotor no hay nada 'jugo'.
Le recomiendo la eliminación de los pinceles de nuevo para comprobar que ambosestén instaladas correctamente. La ilustración de arriba debe permitir volver a instalarlos pinceles con confianza. Buena suerte, espero que esto ayude. Howard, Burke, VA,EE.UU.
Si esta solución ha sido útil, por favor, valoren, gracias! - hslincoln
Feb 10, 2011 | KitchenAid K45SS Classic Stand Mixer
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
Mi batidora no prende
Hola EBANY780, veo tu pregunta es acerca de su licuadora, pero le fue anunciado en la mezcladores KitchenAid. Mi solución puede funcionar, pero posiblemente no.
Usted ha dicho, "Yo pongo [en] mi pincel" - Supongo cepillo de la licuadora de motor eléctrico(s), así que recomiendo que pruebe lo siguiente.
Sólo hay una manera de volver a instalar los pinceles y eso es lo que tanto el asiento correctamente en colector del inducido o no se va a cualquier jugo "al motor. Véase la ilustración de abajo:99839ea.jpg Si te has vuelto un cepillo de 90 grados demasiado, no encaja correctamente y tendrás el poder para el motor.
En esta ilustración se debe permitir volver a instalar los pinceles con confianza. Buena suerte, espero que esta ayuda. Howard, Burke, VA, EE.UU.
Si esta solución ha sido útil, por favor, tasa que, gracias!
- hslincoln
Jul 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Quisiera saber las instrucciones de uso de esta batidora
Mar 01, 2010 | Hobart A200 Stand Mixer
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart hl600 mixer
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart H600 Stand Mixer Logo
307 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
