Question about Avocent DSR8020 KVM over IP Switch KVM switch PS2 CAT5 16 ports 1 local user 8 IP users (DSR8020G01)
Mouse cursor is reponding too much slo - Avocent DSR8020 KVM over IP Switch KVM switch PS2 CAT5 16 ports 1 local user 8 IP users (DSR8020G01)
  • 60 Answers
Check your Mouse acceleration on your target, make sure that the Mouse acceleration is turned off.
Do you see this only on the Web interface or also on the local port? If on both try to upgrade the firmware of the switch, which might take care of your issue.
Posted on May 12, 2011
Mouse does not move cursor, button works though
It could be the light, but have you tried using a different less reflective surface?
Feb 17, 2014 | Quill AirObic Mouse - Right / Left Hand
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
The touchpad will move the cursor but will not repond to double touching it to select an item.
in your control panel, look for mouse, and then there is a little jack in the box icon there to test the sensitivity of the double tap for the touchpad. try adjusting it there
Good Luck!
Dec 27, 2009 | HP Pavilion dv6000z Notebook
Cursor jumps all over with a touch of the mouse why
trackballs and other ball mouses have an optical sensor inside the cup that holds the ball. dirt, lint and debris that falls into the optical sensor can make the cursor jump around - the sensor detects the debris as if it were a ball movement. Clean the inside of the cup and the jumping should stop.
Cleaning the cup -- first clean the three points that hold the ball up. They tend to grap whatever dirt or grease gets onto the ball from the user's hand. Clean the rectangular sensor window with a que-tip or by blowing into it. Get any stuck debris out of the corners. Finally, turn the mouse over, without the bal inside, and tap it on a hard surface. This can knock loose any remaining debris that can fall into the sensor window.
Dec 11, 2009 | Logitech Trackman Marble FX Trackball
How can i change my mouse cursor??(flower)to the normal pointer just the arrow one..
ok fallow these steps
clike start menu>settings>control panel>mouse>pointer>go to scheme and select none and apply changes.
your mouse cursor will become normal.
regards
gaurav rajput
Feb 12, 2008 | Computers & Internet
Keypad don't work
The mouse pad doesn't respond to the cursor. I even tried installing a mouse and it didn't work.
Jan 07, 2008 | Acer 2581168-0001 Keyboard
T20 cursor frozen
Computer mouse help and information A mouse is a hardware device which allows the user to control a cursor to manipulate data .... CH000981, The wheel on my mouse is not working properly.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
E-mail CHID: 6268 This feature enables you to move a mouse cursor or use mous buttons using ... also possible that your keyboard could be bad, causing the keys not to work.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T20 Notebook
Wireless mouse
I just read one of the other solutions, and it was to try and press the reset and mouse reset buttons together - woked for me! yay!
Louise
Dec 08, 2007 | Belkin Optical Mouse F8E850-OPT
Logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Oct 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Avocent DSR8020 KVM over IP Switch  KVM switch  PS2  CAT5  16 ports  1 local user  8 IP users (DSR8020G01) Logo
103 people viewed this question
Top Avocent Computers & Internet Experts
gary433
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
