Question about Vision Televison & Video
Channels other than bbcbreaking up - Vision Televison & Video
    Brigadier General:
  • 8,909 Answers
I would say that was signal problems. IBA and BBC use different frequencies.
Posted on Mar 11, 2011
How can I Watch Music Channels on Your Roku
Roku has variety of channels including music channels. Roku's music channels feature popular streaming apps along with music and videos in every imaginable genre, including classics.
• iHeartRadio
• VEVO
• Tiny Desk Concerts
• Pandora
• Baeble
• TuneIn Radio
• Amazon Music
• AccuRadio
• Classic Country Music
Get complete information about Roku sports channels, news, movies, TV shows etc.
Roku channels Archives Roku com link Activation Support
Sep 27, 2017 | Roku Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
Televison & Video Logo
35 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
