Question about Olivetti wireless All-In-One InkJet Printer
I have an olivetti any way photo wireless plus and the black cartridge is printing shadows. I've cleaned the print heads, done the aligment but nothing seems to work. Can you help?
3 Suggested Answers
SOURCE: windows 7 driver for Olivetti any_way photo wireless plus
If you download and unzipp the Vista Drivers find them in the Olivetti folder click on drivers, then eng, right click on the driver setup and select properties - then compatibility then select run the program in Windows Vista compatibility mode. It worked for me :)
Posted on May 16, 2010
SOURCE: I install a new Black
To Head aligment, Its simple, open a document and select print from the menu,
- In the print screen window select 'properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc... which you can do it for your self after reading each descriptions.
Hope this helps, please rate and leave a comment if this solution was helpful, thank you!
Posted on Aug 11, 2011
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart C4280 Aio Printer
My epson stylus photo printer is printing a black vertical line in all my prints. I have done the head cleaning and print head alignment several times. Is there anything else I can do?
black vertical lines on the printout comes due to some reasons.
1) if the black cartridge is near to its end it will give black lines instead of proper printing.
the cartridges gets over many times due to head cleaning and deep cleaning.in 3-4 cleanings cartridge gets over.in one cleaning 4 ml of ink gets puled out of cartridge.the whole quantity of cartridge is near to 25 ml.
but if the cartridge is full then the problem is of cartridge head .the head is the part in which you insert the cartridges if the head is got blocked internally to its holes from where ink comes out.then there are two methods to clean the head one is head cleaning which you did.the other is removing the head by disassembling the printer and then cleaning the head manually with isoprophyll liquid.but its a time consuming and tough job.a local printer repair center will be advisable,
and in some cases it has seen that cartridge gets air pressure problem inside and due to that it leaks inside the printer so replacing that cartridge solves the problem.also many times the cartridge gets leaked and that leaked ink gets collected and stuck up on the roller of the printer from where paper passes so the strips of ink gets printed on the paper.in this case no head cleaning but cleaning the internal roller of the printer with tissue paper helps.the procedure is called servicing.that can also be done at local printer repair center.or you can do it manually by using tissue paper.but to service whole printer it needs to be disassemble.
check out his option.thanks.
Nov 20, 2009 | Epson Stylus Photo 1290 InkJet Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
Won't print black( will print black on photo!)
clean the print head , this is due to black head problem
Oct 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
MP780 vertical lines on photos
Hi. the problem is the print head, maybe is clogged or damage, try this remove the cartridges , and the print head and submerge the print head in hot water for 3 minutes, dry the print head and reinstall it, if problem persist replace the print head.
TCT How to remove and clean Canon Printhead
May 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
Olivetti wireless All-In-One InkJet Printer Logo
48 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
