My toshiba laptop works on battery fine, but cutting out when the Ac power cord is plug in
  • 35 Answers
It sounds like the solder joint has broken which connects the DC power jack to the mainboard. This can be repaired by re-soldering either yourself or by a technician. Occasionally the DC power jack itself needs to be replaced.
http://www.youtube.com/watch?v=Im_n9K-14_I
Posted on Mar 11, 2011
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Laptop shuts off when AC adapter plugged in and my bettry is new
Try the laptop without the battery in it. If it will not power on just using the cord, then you know that the cord or the power inlet is bad.
If it works fine without the battery, then you'll know that either your battery is not good, the connection between the battery and the laptop is bad, or there isn't enough power reaching the battery connector.
Nov 14, 2012 | Toshiba Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My battery doesn't recharge laptop when laptop is plugged in . What to do and at what approximate cost if new battery needed?
Hi there! There are two possible causes of the problem - it's either your battery or your AC Adapter. To diagnose whether or not it is your AC Adapter, test it this way. Does your laptop function with the power cord plugged in and the battery out? If this is the case, your AC adapter is fine and your battery is done. To replace the battery, expect somewhere between $75-$175. Here is a link to the cheapest battery site I've found so far - I use it for work all the time. http://www.batterydepot.com/mfg/TOSHIBA/LAPTOP-BATTERIES
If your laptop doesn't work with just the AC adapter plugged in, then that is your problem! AC Adapters are cheaper than the batteries. They can be purchased here for around $50: http://www.buylaptopadapter.com/toshiba-adapters.html
Make sure you match the model number on the bottom of your laptop perfectly with the model number of the battery or AC Adapter! Good luck! Alex
Apr 30, 2011 | Toshiba Satellite PSPA0U01S006 Notebook
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Strange ac cord/power issues
Hello my friend, Try to check your battery if the is it working normal cause sometimes the battery itself has the problem its either lost contact or the battery is not charging or not normal. also try to see if the the the sensor or that links the battery to the software which is responsible to the update of charging energy is functioning normal but this is a rare possibility try to focus on the battery or the connector or power cord.
Hope this will able to help solve you problem. If you need more assistance just reply to this post. Thank you
Jonas
Apr 20, 2009 | Toshiba Satellite P15-S420 Notebook
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Computers & Internet Logo
David Payne
David Payne
