Question about Brother IntelliFax-2820 Laser Fax
Every time i ask for 1 print. the machine pulls a 2nd sheet of paper .the 2nnd one gets jam inside. if i ask a report (1 sheet) it always pulls 2. i blow air in all the sensors,got no effect. im starting to think the feed rollers clutch can be the cause... its a 2820 model and im a copying machines technician.
  • 37 Answers
...I'm starting to think the feed rollers clutch can be the cause..
Yes, it is!
(Dal nome credo che tu sia italiano, dunque il problema sta nel gommino antirumore che si trova sul solenioide presa carta che fa rimanere incollata la leva di sgancio. Basta che lo togli e hai risolto.)
Ciao
Posted on Mar 18, 2011
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Im getting an error mp5100, after a paper jam that was removed and the error continues even though I turned the printer off several times
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch
Oct 26, 2010 | Canon Pixma MP480 All-In-One InkJet...
Keeps asking for paper and will not print
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
vote me if you find your solution
Aug 11, 2010 | Canon PIXMA MX310 All-In-One Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 03, 2008 | Office Equipment & Supplies
Brother IntelliFax-2820 Laser Fax Logo
112 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
