Question about 300 Amp Battery Jumper with Air Compressor by
How to tell if battery is full charged before using it.
    President:
  • 1,140 Answers
The easiest and best way to test any battery is with a volt-meter.
http://www.northerntool.com/shop/tools/product_12496_12496
The link above is for a multi-meter. These are inexpensive and are an extremely useful tool to have. For about $15-20 you can buy a meter which will test AC/DV voltage, resistance/continuity and often diodes and/or transistors as well.
A fully-charged 12v battery will give a reading of 12v (or very close to 12v) on a volt-meter when it is fully-charged. 6v batteries should read 6v, 1.5v batteries should read 1.5v, etc, etc.
If the reading is lower than the power output of the battery, the battery is either not fully-charged or one or more cells may be damaged. If cells are damaged, you will never get the full 12v output from a 12v battery.
There are other ways to test batteries but they are less accurate. It's possible to use a battery charger, but you can only use this to determine whether a battery is fully-charged if the battery is known to be good. A fully-charged battery should draw 0 amps on a battery charger, but a damaged battery may also draw 0 amps so this is not a good test.
Basically, I'd suggest you get yourself a multi-meter. You be glad you did!
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Posted on Mar 11, 2011
My galaxy tab :- just bopught for 2 mths. Charge full at night and the next day evening battery totally 0%. I havent got any chance to play with it yet. i charge it full again and this time I thought...
Hello Sir !! I am afraid to tell that your battery might be got damaged by over charging.Electronic devices must be unplugged when the icon comes "Battery is Full" or like wise.Over charging damages the efficiency and produces extra heat that reduces the strength of charged battery.I suggest you to unplug the tab as soon as it got charged.It might increase your battery timings. If this information was helpful please rate or token of appreciation will be esteemed.
Mar 29, 2011 | Samsung Tablets & eReaders
Tip
Battery First Charge On Cellular Phones
When you first get a cell phone, the manufacturer and most likely the store will tell you to immediately put it on charge. DONT! <br /> The best thing to do is use the charge that is on the battery already until it is dead, then give it one full charge. <br /> This will mean the battery's 'memory' will know a full charge from the word go which means that not only will a full charge last longer but the battery will last longer overall.
on Feb 11, 2011 | Cell Phones
Any time I try to turn my camera on it always tells me to "change the batteries" even when the batteries are brand new.
Have you tried charging the brand new batteries? Often batteries are shipped with little or no charge in them, and need a full charge before use.
Mar 07, 2011 | Cameras
J.hughesneed to know when battery is full shows a white battery is that the color when full or is it still not charged
batterys usually show half colour when not full.
watch the battery indicator from time to time with mains power disconnected to see change
usually when charging the the indictor will flash.
run mouse over indictor if on screen and it should tell you how much % of battery is still left.
not possible to be more specific without model number
I hope this was useful.
Jan 11, 2011 | Computers & Internet
Hi, I am usinh Nokia N72 from past almost 3 years. It was working fine till 2 months back. It used to get switch off after every 5 mins..automatically. Then, we showed it at Nokia service centre at...
The battery may not be charged to full capacity. Does the battery show full charge when you charge it for 12 hours?
The adapter may be faulty. Check the battery indicator on the phone when it is being charged.
Sep 22, 2010 | Nokia N72 Cellular Phone
I have problem in my nokia n 91 that its showing on the display charging while charge , but actually the battery is not get charged, i have replaced a new battery already, still the problem is not solved !...
its the cgarging ic of your phone the problem..replace it and your phones charging is ok ,the other solution is using desktop charger...you charge the battery to the desktop charger and when its full charge you can use it ...
Jun 02, 2010 | Nokia N91 Cellular Phone
I have a 3805 Philips shaver - no low battery indicator - how do i know when charged?
The 3805 has only a green charging indicator. This light will illuminate solidly when plugged in. Charging takes a full 8 hours. There is no indicator to tell you when to recharge. If the batteries are in good condition, you should be able to use the shaver for 7-10 days on a full charge
Mar 13, 2010 | Philips Health & Beauty
Alternator tests good ot store but on car only reads 12.4 volts and 4 to 6 amps. regulator was replaced with new alternator . 1969 cougar v-8
sounds like a bad battery - check that -even if new try a well known used battery if you need to. Also charge the battery to full charge and then try it. Many ford [ merc] will tell you do not install a battery that is not fully charged as it will cause problems with the charging system. As a last resort try a new battery with a FULL CHARGE and check the wiring for very hard places near the alternator. These can be a sign of working the assembly too hard. Consider replacing the 'hard' portions of the wires.
Jan 12, 2010 | Mercury Cougar Cars & Trucks
Batterys not reaching full charge
You can try this it might take a while but it should work , use the drill untill it actually stops, use it really hard , then recharge for the full time then use the drill again untill it stops [drain the battery ] even get the kids to hold the trigger untill it stops then recharge again eventually you will remove the memory block off the battery , works for me everytime smirf617
Jun 06, 2009 | Hitachi Tools KC18DCL 18V Lithium-ion...
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
300 Amp Battery Jumper with Air Compressor by Logo
379 people viewed this question
Top Wagan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Wagan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
