Question about Cycling
BMW r1200c won't start, has new battery n pump...it cranks only.
  • 298 Answers
SOURCE: install a battery in a bmw r1200c motorcycle
Hi there!
Try this link below:
http://www.carlsalter.com/aaman/BMW_R1200_RepROM.rar
Hope this helps!
-levibit-
Posted on Mar 20, 2009
gordanddar
  • 477 Answers
SOURCE: engine cranks car won't start
Sorry..... 1 notch off is just not good enough. It has to be exact , then if it doesn't run start looking at other posibilities.
Remember that the camshaft turns twice eash time the crank turns once. The distributor rotor works off a gear on the cam.
Your rotor could be off a bit , or it could look exactly perfect the way it was when tou took it out , and still be 180 degrees off.
You have to get your engine to "top dead center" and make sure everything is the way it should be.
A timing chain ( or belt ) can cause permanent and fatal damage to the valve train and pistons in motors that are "interference engines" Find out weather yours is. In a non-interference engine , the clearance between the valves and the pistons is large enough to alow them to move out of time without crashing into each other. An interference engine is not so forgiving.
The fact that your engine cranks makes me hopefull that it is a non interference engine , and that damage has not been done.
Try to find a haynes manual for you vehicle , it will walk you through the steps for most repairs.
Posted on May 10, 2009
  • 10 Answers
SOURCE: I remplace a new alternator and battery on a BMW x5 2001 it won'
theres an anti-theft system. take positive terminal off battery, have someone holding the key on like trying to start it, then put the terminal back on and that should start it right up (had same problem in my dodge ram) if not, check all you're connections
Posted on Aug 16, 2009
  • 113 Answers
SOURCE: Where can i buy a
Clymer lists a manual covering the R1200C as item #M5033.
the BMW factory manual is available from your BMW dealer in CD.
You need a special bleed fitting to bleed the clutch on your R1200C motorcycle. Other than the special fitting, the clutch bleed process is very conventional. I can't locate the part number for the speacial fitting right now, but a goood BMW dealer can order it for you.
Posted on Sep 26, 2010
Testimonial: "Thanks for the responce"
  • 5370 Answers
SOURCE: My bmw 320i e90 2005 only cranks but won't start
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Posted on Mar 01, 2012
I need a fuel pump wiring diagram for a 1998 BMW R1200C
Hi Keith, I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $6.50 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://178.62.242.206/docs~1998-bmw-r1200c-wiring-diagram.pdf
Sep 24, 2013 | 1998 BMW R 1200 C
Http www fixya com
Hi Keith, for more information about your question please visit the website below. Good luck and have a nice day.
Sep 24, 2013 | BMW Motorcycles
Where is the battery on a 2003 bmw r1200cl? under gas tank?55@@
Hi, Fakb55 I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
BMW R1200C Prep Gas Tank Removal for Battery Install Part 1 of Tips Tricks
Bmw r1200c montauk service manual
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Mar 30, 2011 | 2003 BMW R 1200 CL
My wife and I have two bmw r1200c's a 2000 and a 2001. Both ran fine un til the battery died on the wifes. replaced the battery with one from a battery shop. Difference was BMW battery was a 12v 19ah, the...
No, very unlikely that the battery has anything to do with this problem
When you changed out the battery, did you remove the fuel tank completely or just prop it up??
There are two fuel lines (supply,return) and an electrical connector for the fuel pump that must be disconnected when you remove the tank.
I would suggest taking a close look on the RHS of the tank near the seat and ensure that the fuel pump connector is properly seated and that the fuel lines are properly connected.
Good Luck!
Oct 29, 2010 | 1998 BMW R 1200 C
Where can i buy a repair manual for BMW R1200C ? or does anyone know how to bleed the clutch on the R1200C ?
Sep 26, 2010 | 1998 BMW R 1200 C
My bmw will not start
Need more info. Do you hear the fuel pump kick on when you turn the key to the on position? Does the engine crank over at all?Do your lights go dim when you engage the starter?
Dec 20, 2009 | 2003 BMW 325
Cycling Logo
32 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
