Question about Amazon Kindle Wireless Reading Device
On sleep mode, would not wake even if i slide the switch and hold it for 20 seconds.
  • 126 Answers
The hard reset takes 45 seconds sliding the button, It also might have run out of battery which puts it into a mode that looks like sleep mode
Posted on Mar 11, 2011
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
After charging my IPAD says IPAD is disabled and underneath it says connect to iTunes. what do I do?
Try putting it into DFU mode which is
-hold sleep/wake and home button untill it turns off
-let go of sleep/wake button still hold home button for about 10 seconds
-plug it up to iitunes
-and it should be there
Dec 30, 2015 | Apple iPad Air 9.7" 32 GB Wi-Fi Space Gray...
What would make my ipad just light and i can't get anything on it?
Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
Nov 17, 2015 | Apple iPad Mini
My Kindle Fire HD won't turn off. I was watching a movie on Netflix and the picture just froze
Turning Off the Kindle
Quickly sliding the power switch on the Kindle enters and resumes sleep mode. If your Kindle enters a non-responsive state when sliding the power switch, you've likely entered sleep mode. Try sliding the power switch and holding it for four seconds to shut down the device. If it still does not shut off, you may need to reset the Kindle.
Resetting the Kindle
The power switch also serves to reset the device. Before resetting the device, disconnect it from any power sources, such as an AC outlet or your computer's USB connection. Sliding the power switch and holding it for 20 seconds forces the Kindle to reset and power down. However, a nearly depleted battery may prevent this action. If the Kindle still doesn't shut off, try charging it for several hours and resetting it again.
Mar 17, 2015 | Amazon Kindle Fire HD 8.9"
Sound effects icon on iPad won't go away
try this steps:
Restarting, resetting, or Force quitting the apps.
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Force quit an app: Press and hold the Sleep/Wake button on top of iPad for a few seconds until a red slider appears, then press and hold the Home button until the app quits.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Jan 18, 2015 | Apple iPad Tablets & eReaders
My ipad shows a picture of the itunes icon with the plug in going to it. What do i do?
That icon is telling you that you must set up your iPad with iTunes or update iTunes on your computer
Mar 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is dead how do i restart?
for Iphone ,ipad, ipod
Step One
Open iTunes and connect the iPhone to your Mac or PC.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
restor it.
May 07, 2011 | Apple iPad 64 GB 3G Tablet PC
IPAD is disabled
you need to DFU restore your iPhone. Hope you got a backup, because you're losing the stuff on it. with iPad plugged in, hold down the sleep wake switch, and the home button for about 10 seconds, until the iPad turns off. Once the screen goes black, continue holding, count to 8. Release sleep wake switch, continue depressing home button. Wait for iTunes to recognize, and you'll be prompted to restore.
Feb 07, 2011 | Apple iPad 32 GB 3G Tablet PC
Cannot wake up kindle even after sliding power switch
Try to slide and hold the power switch for about five seconds, until after the power LED behind the power switch blinks three times.
Dec 31, 2010 | Amazon Kindle Wireless Reading Device
Amazon Kindle Wireless Reading Device Logo
205 people viewed this question
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
