I have problem connecting my Cheeta internet high speed cable to my external modem to my Links WRT54GS to my Dell Inspiron 1501 that uses Vista Home Premium as its operating system.
After my time ran out, I was able to get the Cheetah connected to my Linksys router. Many thanks for your help!
Posted on Aug 01, 2008
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
Dell inspiron e1505 will not connect to internet by wifi
what operating system you use?
if you use Windows Vista or 7 try to update from Windows Update via LAN.
Feb 01, 2011 | Dell Inspiron 1501 Notebook
I have a dell inspirion with vista and I can not connect to the internet using a cable modem.
Have you tried disabling your firewalls, f it came with norton 360 or norton internet security remove it and then try connecting if you can then its your firewall stopping it
another way to try without uninstalling is to click on the start button then in the search box type CMD and press return
in the command prompt that opens type
ping www.google.com and hit enter
if you get four packets sent and four received your firewall is blocking the internet connection. Remove it try the internet if it works reinstall it and it will detect the new network and allow you access.
type ipconfig in the command prompt window and hit enter if you get a 169.x,x,x x=any number then the laptop has no ip. Make sure that the network card isnt disabled
if they all fail and the laptop hasnt got an ip address, then the problem is the cable modem, is the internet active? I.e. you can plug it into another pc and it works
Oct 30, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron will not connect to any internet
Sounds like perhaps you have a winsock error.
http://support.microsoft.com/kb/811259
Hope that helps you. Just FYI, a corrupted WINSOCK issue is usually the result of a virus or spyware corruption.
Oct 26, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
My dell inspiron 1501 does not find modem
reinstall the driver or either defragment by simply clicking on ur start button,go to accesories,tools and select the drive and then reinstall
May 27, 2009 | Dell Inspiron 1501 Notebook
Trying to set up wireless laptop. Instructions tell me to input
The wireless connection device on a computer is used to connect to a wireless router that is connected to the Internet via an Internet Service Provider (ISP) and or to your home or the network where you work. You can also use it connect to a wireless hot spot (like an Internet cafe) for Internet access.
Your computer will need a wireless device either a built-in wireless card, or a PCMCIA wireless card that plugs into your computer's PCMCIA slot or a USB wireless device.
If you want to connect into the Internet wirelessly in your home, you need a wireles router that is connected to a cable modem or a DSL modem and to a ISP.
The wireless router needs to be configured (change the default settings) the SSID and encryption (WEP or WAP, WAP is a stronger encryption method) etc.
The wireless card needs to be configured with the same settings as the wireless router so it can communicate with the wireless router.
For configuration information refer to the wireless router and wireless card/device manuals.
Whilst the settings of these devices are similar between the various manufacturers, the methods they use to configure varies and you need to be precise in giving make and model of the devices, your Windows system and computer to assist us to give you detailed advice.
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Wireless router
well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
May 28, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
