Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
My DLP 6163W has been erratically turning on and off with the flashing lamp on. Occassionally it works fine but it doesnt last that long and it goes back to on and off with black screen only. What seems to be the problem here?
  • Samsung Master
  • 2,098 Answers
Hi gflores723,
This is an indication of out-of-regulation in the power supply section. The very common caused of this fault is the leaky electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 11, 2011
When turned on the lamp led flashes, the bulb appears to lite up but the picture can take several minutes to come on then the set works fine until shut off. please any ideas ward
If lamp has not been replaced in tv in last 2-3 years then it seems time to get it replace.
Lamp replacement procedure is easy and written in user manual of tv.
Thanks.
Jan 05, 2011 | Samsung HL-S5087W DLP TV
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
Samsung dlp tv turns on works fine but after 15 minutes turns itself back off
This happens due to increasing heat in tv, check exhaust fan is running and throwing hot air out of tv, check temp sensor is working fine mounted on lamp housing.
When did you replaced lamp last time in tv?
A weak lamp also does same problem.
Aug 24, 2010 | Samsung Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Tv will not work
Thunderstorm will damaged the semiconductor such as signal diode, transistor, and IC. Check any shorted component in power supply section. You need Multimeter and basic component testing procedure.
Jun 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid...
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
My TV blinking timer, lamp and stand by. is that lamp defective? Can you please tell what to do or any other probelem? email: vijoypk@hotmail.com vijoy
Most DLP tv's have an internal lamp hours counter. Once the preset number of hours has been reached, an indicator will start flashing letting you know it is time to change the lamp. Now, if your tv is working fine, reference your owners manual and reset the lamp timer to turn off this indicator. You will probably be replacing your lamp soon, but wait until it goes bad. Hope this helps
Dec 07, 2008 | Televison & Video
Hello. I have a Zenith DLP Projection TV that I bought new from the store (possibly the display in the store) that has been working fine for 2 years. Just only a few weeks ago, the color seemed a...
Sounds like you need to replace your lamp and the tv will work fine until the new lamp goes out. I have had three lamps since Nov 2006 in mine and I have a notice coming up on my Panasonic saying I need to change the lamp right now. Which is strange, because before there was no warning, it worked fine and then when we went to turn it on again, it just did not work until the lamp was replaced.
Oct 05, 2008 | Televison & Video
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
