Question about Sharp AR-5320 Black and White Copier
How is the maintenance process? - Sharp AR-5320 Black and White Copier
  • 4 Answers
Process unit clean by removing excess toner, developing unit being careful not to drop the developer, clean the paper feed rollers, exposure mirrors, laser crystal.
check heat and pressure rollers and bushings, clean the paper path in the document feeder, clean the platen and the strip of white correction.
at the end, use the sequence:
#, *, C, *, 20, start, 1, start.
to reset the maintenance counter.
hope this helps you...
Posted on Mar 14, 2011
I'm getting error 94,7000.00:114.36 on my Xerox 8570 Printer. It sounds like a lot of spinning on the maintenance kit when I boot it. Any suggestions?
The error is a Process Drive Fault. This may be a problem with the Process Drive's Gears.
You probably need to go through the replacement procedure again.
Xerox says to check if they are in their home positions. NOTE: Usually, manually tilting the head back and forth using Drum Maintenance Shaft should leave the Process Drive aligned.
Sep 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Tip
Ford Edge Vista roof maintenance
This is part two of the vista roof maintenance, cleaning, re-installation and the Intitialization process along with timed results for the evidence to prove the cleaning worked.
Ford Edge Panoramic Vista Roof Maintenance Part 2
on Aug 25, 2016 | Ford Cars & Trucks
I have a 07,010.43:45789 error code pop up. Any ideas?
7,010.43: The Printhead is stuck in the tilted position,
or is not able to tilt forward to the print position, due to problems.
Reboot the printer.
Repair or replace the Printhead Restraints.
Has ink spilled ink around the Printhead that prevents the Printhead from moving to its center position? You should be able to push the Printhead right to left. Clean the Printhead area.
Is the Printhead stuck to the Wiper Blade? Start the printer in diagnostics mode and run idiags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5
Does the X-Axis Motor drive the Printhead to its center position (so it can tilt forward)?
6
Check the Process Drive for obstructions or damaged.
Ensure the gears are correctly aligned and homed.
Verify the process shaft and drive module shaft are at their home positions.
7
Has ink spilled on the Head Tilt Gear on its drive train (near left side of the Printhead)?
8
Use Service Diagnostics to run the Head Maintenance Wiper Clutch test. If the test fails replace the Head Maintenance Clutch.
9
Align the Wiper Assembly. Use Service Diagnostics to run the Wiper Drive Test. If the test fails replace the Exit Module.
10
Use Service Diagnostics to run the Load Maintenance Clutch test.
If the test fails inspect the maintenance drive system, replace any defective parts.
11
Verify the Head Tilt Gear engages. You can manually set the Head Tilt Gear.
12
Use Service Diagnostics to run the Tilt Axis Drive test.
If the test fails replace the Process Drive.
13
Use Service Diagnostics to run the Process Motor test.
Aug 13, 2014 | Xerox Phaser 8560MFP Laser Printer
THE TASKMANAGER'S PERFORMANCE SHOWS 100% USAGE EVEN WHEN THE COMPUTER IS NOT PERFORMING ANY TASK.SPEED OF THE COMPUTER HAS BECOME VERY SLOW.
Start by identifying the processes which are using the cpu and stop them or disable the processes which are causing the usage.
Mar 07, 2011 | Computers & Internet
07,010,43:49314 system error
Here is the solution for your problem.
7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
1. Reboot the system.
2. Did this correct the problem?
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or replace the lock arms.
3 1. Is there spilled ink around the printhead? Clean the print-head area.
Go to Step 4.
4 1.
Check the process gearbox for obstructions
or damaged.
4.2. Ensure the gears are correctly aligned and homed.
4.3. Verify the process shaft and drive module
4.4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
5.2. Is the gear engaged properly?
Go to Step 6. Set the head tilt gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
6.2. Did the test fail?
Replace the process gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
7.2. Did the test fail?Replace the process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
test.
8.2. Did the test fail?Replace the wiper drive clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
9.2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Go to Step 10. Replace the exit module assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
10.2. Did the test fail?Inspect the maintenance drive system, replace any defective
parts.
Hope this helps and rate your response.
Thanks, SF
Feb 18, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Error code 07,010,43:13829 xerox c2424
Hi sales1stsupp:
Here is your problem.
replace the lock
arms.
printhead area.
Go to Step 4.
or damaged.
homed.
Go to Step 6. Set the headtilt
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
Motor
test.
Replace the
process motor.
Go to Step 8.
test.
Replace the
wiper drive
clutch.
Go to Step 9.
Drive
Test.
exit module
assembly.
Maintenance Clutch
test.
parts
Hope this helps
Apr 22, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
This error means the printhead is tilted back but not properly restrained by the print-head restraints.
There are several possibilities.
First. The right or left print-head restraints often crack not holding the print-head in the restrained position. Remove the side covers and you can see them inside the frame about center at the top, they are glossy black unlike the frame.
Second. The maintenance camshaft (behind the maintenance pivot plate) may have cracked cams not allowing the the maintenance pivot plate (this holds the maintenance kit) to move to home position. This causes the process gearbox to be out of the correct home position.
Third. The process motor may not be aligned correctly or even may be bad - broken or worn teeth. This is on the right side in the front lower corner.
There are other possibilities but more rare.
Hope this helps. At least you have an idea of the problem.
Dan
Nov 04, 2008 | Xerox Phaser 8500/DN Printer
Hallo
07,009.42 indicates that the printhead was unable to tilt normally on its axis.
You probably have a cracked drum maintenance camshaft. If the drum maintenance pivot plate is white plastic it should be replaced as well with the new style, which is black plastic. This repair requires removing the process drive gears assembly and reinstalling it requires the gears to be timed. This repair should be performed by a qualified technician familiar with these machines.
You probably have a cracked drum maintenance camshaft. The dm camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about $17 from xerox but can be tricky to replace if you're not mechanically inclined. The other thing to look at is the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If it's white it will also need to be replaced with a black one.
Oct 15, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8200DP error 07,002.44:40280 Can you identify this fault for me and tell me how fixable it is?
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic test. Also exercise processes run with the process motor; transfix, drum maintenance and head tilt. This can be caused by the power control board. The process motor may have more than one task initiated. Reset all solenoids and the pressure roller prior to cycling power.
Aug 11, 2008 | Xerox Phaser 8400 Laser Printer
Sharp AR-5320 Black and White Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
