Question about LG Televison & Video
I lost the manual to my DR275 recorder and cant remember how to tune it in to the tv stations and set the timer to record
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 11, 2011
Would like to tape from tv.
this should help jar your memory some....if your vcr is set/tuned to ch 3...and tv is set to ch 3....cable/dish box is your ch selector (tune to any ch u wish) put a blank tape in press record if you want to record....(you are not home, you must set the timer on the vcr /menu/timer recording settings)...make sure the cable box is set to the ch you wish to record...or else you will miss your recording you want.
Jul 10, 2010 | Sharp VC-A582U VCR
HOW TO INITIATE SET-UP PROCEDURE FOR 2ND HAND VIDEO/DVD PLAYER
You should have the main aerial going into the dvd and then a black flylead going back into the tv.If you go into the on screen menu you find a set section so you can re-tune the stations.
Aug 17, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Analog VCR Model SDV394SU on cable will tune stations and record the current station, but will not start for for programmed (on/off timed) recording. In other words, when you program the VCR to start at a...
The answer to your question, "Does this have anything to do with the fact that the VCR and TV are now on cable?" is no.
The outside antenna and the cable are input signal sources only and have no effect on the functions of the VCR.
It sounds like you have an electronic problem with the timer circuitry. In order to locate exactly where the timer circuitry is located, you would need a service manual for your particular VCR. Using the service manual, you may or may not be able to repair it.
My suspicion is that it would be cheaper to just purchase a new VCR if timed recording is important to you.
Aug 07, 2009 | Toshiba Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Problem with LG DR275 Recorder
lens needs cleaning or replacing
May 09, 2009 | LG DR275 Recorder
I need the manual of dvd recorder model dr275
You can find the manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/DR275-_D
Click on the download link on the right side, then enter the 4 numbers so you can download the manual.
If you appreciate the time I took to help with this, please take the time to rate my response.
Hope this helps,
Chris
Jan 02, 2009 | LG DR275 Recorder
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
My Sansui recorder records blank when I use the timer!
first of all make sure the time and date is set correctly on your recorder (options or set-up usually) second make sure an aerial input is going to your recorder (not just to your tv (the recorder is in the loop with aerial lead to it then from it to tv)) third make sure the on-board tuners are tuned to the correct tv channels (recorder is just a tv without a screen and has its own channels that need to be tuned in)
Jul 13, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
LG DR275 timer recording problem
I found the answer to the problem eventually,it was because when setting up the recorder I had set the clock to 2007 instead of 2008 everything now working OK
Mar 07, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
108 people viewed this question
Computer Repairing
Computer Repairing
