Question about Ricoh Office Equipment & Supplies
How to remove failiure code sc 322 ? copier
How to remove failiure code sc 322 ? copier machine after change all the electronic boards this code already appear on the screen
  • 3,740 Answers
This is a laser sync error that given everything you have done is probably caused by toner on the OPTICS. It is time to clean up the lenses, mirrors and detectors. It is not a good idea to use canned air or cleaners to do this as it spreads toner in places you do NOT want it.
Kelly
Posted on Mar 11, 2011
Photo copier error code on ricoh 2018 code is 322
SC 322 is as follows.
322 C 1st laser synchronization error The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Causes
• Poor cable connection between the laser synchronization detector board and the LD unit.
• Laser synchronization detector board out of position and angle of reflection not correct
• Laser synchronization detector board defective
• LD unit defective
Basically there is something wrong with the laser unit. It is possible to take it out by removing the front of the copier between the paper tray and paper output deck. UNLESS YOU KNOW WHAT YOU ARE DOING DON'T DO IT. There is a laser in the unit that can cause instant blindness if you defeat the interlocks or repair it incorrectly. An experienced engineer would unplug the machine remove the unit, remove the top cover and clean the mirrors and glasses inside the laser unit without removing any of them, also check that the ribbon cable is correctly plugged in durin reinstallation.
I take no responsibility for these instructions or the text above, the laser unit has warnings on it that should be followed and it should only be repaired by the manufacturer in designated premesis.
Anyway hope this helps :)
Please rate.
Dec 23, 2010 | Ricoh Aficio 2015 Copier
How to remove code sc 322
• The 1st laser synchronization signal
and the LD unit.
not correct
defective
• LD unit defective
Most likley to be polygon mirrow thats faulty.It is inside the lazer unit.If u hear loud winding noise that will point to polygon mirror,or possibly it has seized up and cant turn at all.In any case ull need service engineer to replace it.
Dec 04, 2010 | Ricoh Aficio 1045 Black and White Copier
SC 322
sc 322 how to solve this error
Jun 16, 2010 | Ricoh Aficio 450 Copier
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
the LD unit.
out of position
defective
LD unit defective
May 07, 2009 | Ricoh Aficio 1035 Copier
Sc 322, sc 326 codes
Never heard of this happening to five machines before.  Check the connections in the laser unit.
Oct 25, 2008 | Ricoh Aficio 1035 Copier
Aficio 450
SC 322 is a laser diode problem. It will require service.
Mar 27, 2008 | Ricoh Aficio 450 Copier
318 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
