Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Posted on Mar 13, 2011
What can the problem be if the buzzer goes off every time an refrigerator not cold enough stays on 9
A fridge or freezer will sound an alarm if it can't hold the temperature it is set to keep the interior to.
The cause can be, a bad or not running compressor, or the system lost cooling fluid. (Used to be freon, but not anymore)
Jul 14, 2014 | Samsung CoolTech Plus / Basic Bottom Mount...
What temp should the fridge and freezer sit at?
Your freezer should be at minus 35, and your fridge at about 5 degrees.
Aug 07, 2012 | Samsung CoolTech Plus / Basic Bottom Mount...
What should the temperature be on the non frozen side
Hi
We use Celcius here in Australia but I looked up the conversions.
Optimum temperature for your fridge is 3 or 4 Degrees Celcius. (37.4F to 39.2F)
Optimum temperature for your freezer is -14 to -16 Degrees Celcius. (3.2F to 6.8F)
Ash
Sep 03, 2011 | Kenmore Side by Side Refrigerator
My Samsung model RB1855sl shows the temperatures for the fridge and freezer in celcius. Can you tell me what appropriate temps would be for them to be working? I loaded up with gorceries a few days ago,...
the freezer should be arond -20 degrees celcius and the fridge aroud 5 degrees celcius
There could be a problem with air flow
the fan in the freezer has probably stopped or the air flow into the fridge is probably blocked
You could have a defrost problem. this would allow ice to build up in the freezer blocking off ai flow.
A technician can help you with that
Mar 24, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
I have a Samsung Cooltech Plus fridge that seems not be able regulate the temperature correctly. At times the temparature is 22 celcius and food gets spoilt, I tried switching it off and on again but that...
Keep your hand on condenser coil if it's visible or left and or right side body of the fridge. If you feel hot the gas is o.k. Otherwise no gas or chock. You have to repair and refill the gas.
Dec 08, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
We own a samsung cooltech plus, something, something. The freezer is working fine, but the fridge's temperature suddenly jumped from 3 degrees celsius to 9 degrees celsius. We can't seem to change the...
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Dec 18, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Blinking temperature control
hi
this refrigerator having problem related with defrost cycle.fridge is able to defrost after period.please check it as follows
there is timer box located behind the fridge near to compressor with white color knob.attach the clamp meter on one wire of main cord,check current drawn by fridge when comp.is running.turn the timer knob clockwise to hear big tick sound where the comp.will stop,check the current in meter which should be 0.6amp.if it is not showing then there is problem with bimetal or heater which is inside the frizer
May 01, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
1,345 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
