Question about Hotpoint Washing Machines
I've got a Hotpoint BHWD129. It (quite literally) blew it's heater element, tripping the consumer unit. I've changed the element (and the temp sensor) and it goes through the wash and rinse cycle but when it gets a little way into the spin cycle it throws a wobbly, flashing all the lights under the selection dials (not the ones showing the current program) and the start / stop button also flashes orange (if I remember correctly). Anybody got any ideas of obvious things to check? Surely it can't be the board, otherwise I wouldn't expect it to work through the wash and rinse programs. It drains fine too. It took a lot of banging about for several hours to get the element out as it got itself well and truly stuck (combined with the way it had blown / split couldn't be extracted without much faffing), so wondering if I've knocked a connection somewhere. It's almost like it's trying to work out whether it can perform a full speed spin but can't. The machine appears to be level. Many thanks for any pointers in advance.
  • 917 Answers
The reason the element blew may be a factor. I have a different model but I had a problem with the heating element as well. The spin cycle had been getting noisier over a period of weeks and then the circuit breaker kept tripping on filling up with water. I traced the problem to the heating element and took it out. It had a hole in it, letting the water in and causing a current to earth. The hole was in an area which looked worn down and I realised that the spinning drum must have been spinning on it during the spin cycle. This could only happen it the drum was off-centre. The three prong spider bracket holding the drum was broken. When I finally got it out (not easy), two of the prongs were broken and it was only supported by one prong. I fitted a new spider and it has beeb fine ever since. The spider looks like an aluminium alloy and if aluminium and steel are in contact in the presence of water the aluminium degrades.
Check your drum to see if is loose.
Posted on Mar 11, 2011
Change heater element on hotpoint TVF770K Aquarius dryer now have F13 fault
There is a small thermostat button ontop of the Heater mechanism which has tripped . It has either a red dot or blue dot ontop. Use a pin or opened up paper clip and push through the red wax. It will go click and it is reset. .
It sometimes trips out with a F code which normally trips the machine off because it thinks the Heater unit is on fire.
There is a small disk which costs about £15 to buy which you can change.
You will need HEX screwdriver set to change and open up the Heater matrix to clean the fluff off the element.
Nov 19, 2013 | Hotpoint TVF770 Tumble Dryer
Saunacore 44QRS, is a 120 vac unit. As soon as you turn the elements on it trips the circuit breaker. I've tried plugging into different outlets, even a dedicated 20 amp circuit. The unit is only...
must be running with gfi. run for one hour without neutral wire connected. it will dry moisture content within heater elements. then reconnect neutral wire, and walla, no tripping.
Jul 13, 2011 | Saunacore Standard Residential Sauna...
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
Hi, i have owned my Hotpoint Ultima WT960 washer for 3 years now with no problems, however recently the washer keeps tripping my consumer box. it only trips on the main wash cycles and is fine on rinse and...
I would concur that is probably the element and or thermistor attached to the element that is causing the problem.
Before commiting to replace, try disconnecting the supply to the element and trying it again, if it does not trip, then this proves element and or thermistor faulty.
Jan 04, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Electrics tripping
Yes, it sounds like the element is broken, and it is easy to replace if you have some mechanical ability.
Jan 28, 2009 | Hotpoint Dryers
Error code f13
There is a small disk which costs about £15 to buy which you can change. You will need HEX screwdriver set to change and open up the Heater matrisx to clean the fluff off the element.
Sep 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Washing Machines Logo
314 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
