Question about Lowrance LCX-15MT GPS Receiver
Does it have achart plotter - Lowrance LCX-15MT GPS Receiver
  • 285 Answers
Out of the box, no. To get GPS/Mapping/chartplotting features, you have to hook up a separate LGC-12S 12-parallel channel GPS receiver/antenna device which is sold separately.
Posted on Mar 11, 2011
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
1. PEN NOT LIFTING. HOW DO I ADJUST PEN LIFT 2.PAPER SKEWS TO LEFT 3. NEED SERVICE MANUAL ON SUMMAGRAPHICS PLOTTER HI7200
Installing Pens
Most types of disposable pens must be activated before using the for the first time. If you are installing a new disposable pen:
  1. Press down on the pen cap to break the internal link seal.
  2. Holding the pen with its tip pointing down, shake the pen to start the ink flow.
  3. Remove the cap and test the pen for ink flow on a scrap of paper or media before installing it in the plotter.
    Some types of pens require adaptor sleeves to fit the pen holders in the pen changer and pen carriage. Insert each pen into its adaptor sleeve, if required, before installing it.
Using the Pen Changer
You may find it easier to temporarily raise the pen changer arm to install pens. Press the widest part of each pen into the jaws of each stall in the pen changer. After installing all the pens that you plan to use, lower the pen changer arm until it latches into place.
Notice that the pen changer stalls are numbered 1 through 8 from right to left (viewed from the front of the plotter).
Note: Make sure that the pen changer arm is in its lowered position and latched into place each time you power on or reset the plotter so that the plotter will correctly change pens.
Operating Without the Pen Changer
For operation without the pen changer, position the pen changer arm in the raised position and install a pen directly into the pen carriage by pressing the widest part of the pen body into the jaws of the pen holder on the pen carriage. You can still produce multi-pen plots, if desired, by enabling the PEN PAUSE parameter--------------Online KeyThe Online key toggles the plotter between on-line and off-line operation. The mode is displayed with each key press.
The plotter is initally in the on-line mode at power-on. In the on-line mode, plotting operations are enabled. When media is loaded in the plotter and the plotter has been selected (see below), an on-line plotter begins executing plotting commands from the input buffer as soon as they are received from the host computer.
In the off-line mode, the plotter can still receive data into its input buffer if it has been selected, but plotting operations do not begin until the plotter is switched on-line. The plotter can be operated manually in the off-line mode using the following control panel keys:
  • Pressing the left or right arrow key moves the pen left or right.
  • Pressing the up or down arrow key moves the media in or out of the plotter.
  • Pressing the PEN SELECT key accesses a menu to select a given pen from the pen changer.
  • Pressing the PEN UP/DN key raises or lowers the pen.
Pressing the Online key during plotting switches the plotter off-line and suspends plotting.
Pressing the Online key again will cause plotting to resume at the point of suspension. ------------------Pen Up/Dn Key
The Pen Up/Dn key raises and lowers the pen when the plotter is off-line. If there is no pen in the carriage, pressing the Pen Up/Dn key causes the plotter to retreive the currently selected pen from the pen changer (if the pen changer is installed and is in the lowered position).
Note: After approximately two seconds of no pen movement, the plotter will automatically raise a lowered pen to prevent ink from bleeding on the media, until the pen is moved again. If the pen is not moved for the period set for the AUTO-CAPPING parameter , the plotter will return the pen to its pen changer stall. To restore the currently selected pen to its previous position on the media, press the Pen Up/Dn key or an arrow key. Pen Select Key
When the plotter is off-line, pressing the Pen Select key allows you to select a pen from the pen changer. After pressingPen Select, press the <-- --> keys until the desired pen number is displayed on the lower line of the LCD, then press the Enter key. The plotter will retreive the selected pen from the pen changer.
The Pen Select key is also used in the Configuration Menu,
Oct 16, 2009 | Computers & Internet
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Plotter mt871 will not communicate from computer to plotter
Try getting some generic drivers for plotters and see if they do anything... I would also suggest that you get a JetDirect card or something to interface the Plotter with your network, this should take any misscommunication away.
Jun 20, 2009 | Computers & Internet
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
Lowrance LCX-15MT GPS Receiver Logo
103 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
