Question about Canon NP 6035 Copier
I replace canon plotroller for solving e002 but that plotoroller made in aluminium meterial. So E 002 displaying again. I try to buy plotoroller made in iron. But it is not available in shops.Please help me to solve this problem.
  • Canon Expert
  • 270 Answers
This is code indicating the fuser assembly is not at the correct temperature. You need to check to see if it gets hot. If the fuser is cold you should get a E000. The thermistor is not detecting the fuser temperature correctly. It may have to be replaced. You should try resetting the error first. Open the front door and look for a small hole in the cover below the control panel. With the power on insert a paper clip or something similar and go straight in. You should hear a light click from the swith being depressed. There should be a " $ " on the display. This called service mode. Press * 4 * and this will get you into Fuction mode. Look for ERROR, highlight by depressing it and then press OK. This clears the code from the copier's memory. Turn off the power switch and wait a few seconds and then turn the copier back on. The copier should come up. If the error returns then you will have to find out why the thermistor is not working. I haven't work on this model for several years and can't remember what the display looks like but this should get you in the right direction.
Posted on Apr 14, 2011
E002 error
Symptom
E000/002/003/261/733 may occur when connecting the machine with power source having much noise, such
as a private power generator
<Cause>
The power line noise prevents the normal operation of zero cross signals, causing poor control of power supply
to the fixing heater.
<Factory Measures>
New type of switching regulator PCB is used to decrease the effect of power line noise.
try to change Switching Regulator PCB (FH3-2614-020 ) ..old-FH3-2614-000
Check version of system software
iR3300 Ver.11.01
1)Countermeasure for E002
2)Modification of the temperature adjustment control for free
size paper
3)Multi-purpose tray for B6 size (out of specification)
supported
4)Modification of the problem for the service mode
(REGIST) performance
5)Modification of the problem for the service mode (TRYSTP)
performance
Oct 15, 2013 | Canon NP 6545 Copier
Error 002 np 6050
E002 is a fuser warm up time...
Sep 26, 2011 | Canon NP 6050 Copier
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
E002 and e004 are the errors
E 002 & E 004 is malfuntion the fuser unit.
E 002 : check TH1 termistor,H1 & H2 heater lamp and the thermofuse termostat.
E004 : SSR malfunction.
Aug 01, 2009 | Canon Office Equipment & Supplies
Canon copier make is 6312
E002, fuser is not heating up, you will have to test the fuser lamp/lamps, thermal fuses, and connections.
I could also be the thermistors.
May 19, 2009 | Canon NP 6230 Copier
Showing E002 and not working
E-002 is an error code for the heat unit in your machine and needs reset, You can try turn it off and unplug it for a couple minutes, plug it back in and turn it back on. The heat lamp or a temp fuse may have blown out in that heat section and need replaced.
Good luck
Bob
Apr 17, 2009 | Office Equipment & Supplies
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6035 Copier Logo
20 people viewed this question
old marine
old marine
