Question about Dishwashers
3 short warning tones unable to turn off rinse light at right hand side of controls
  • Dishwashers Master
  • 3,247 Answers
Will need to know the make and model number of the dishwasher
Posted on Mar 11, 2011
  • Sam Mar 14, 2011
    it would have been more useful if you had provided the model number and make of the dishwasher rather than give me a 2 finger rating. No point in listing the problem if you do not want fixya to help.
2006 lincoln town car air bag light is on 5 beeps 5 times
The five beeps - five times would indicate a code 55 , but factory service info only goes to code 53 .
  • Audible tone - DTCs retrieved
  • Air bag SRS system fault
  • REFER to DTC Priority Table.
Did your air bag light flash at all ? Apparently this will do flash the air bag light codes as well .
Symptom Chart Condition Possible Sources Action
  • Air bag warning indicator is illuminated continuously
  • Fuse
  • Damaged wiring, terminals or connectors
  • A faulty diagnostic connector
  • A faulted RCM
  • A faulty instrument cluster
  • Go To Pinpoint Test A .
  • Air bag indicator flashing
  • Air bag/pretensioner supplemental restraint system (SRS) fault
  • No communication with the restraints control module (RCM)
  • Fuse
  • Diagnostic tool
  • Data link connector (DLC)
  • A faulted RCM
  • Circuitry
  • Go To Pinpoint Test V .
LFC - light flash codes .
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Table
DTC a LFC b Description Action To Take - Continuous The Air Bag Indicator is Illuminated Continuously, RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of Signal Ground Go To Pinpoint Test A . B1231 13 Crash Data Memory Full Install a new RCM and impact sensors. REFER to Inspection and Repair After a Supplemental Restraint System (SRS) Deployment . B1317 Continuous Battery Voltage High CHECK battery voltage; to be below 16 volts. REFER to Section 414-01 . B1318 Continuous Battery Voltage Low CHECK battery voltage; to be above 9.0 volts. REFER to Section 414-01 . B1342 12 RCM Is Faulted Install a new RCM. B1869 NONE
Continuous lamp
Secondary air bag warning sounds if another fault is present Lamp Air Bag Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test B . B1870 NONE
Secondary air bag warning sounds if another fault is present Air Bag Warning Indicator Circuit Short to Battery Go To Pinpoint Test C . B1891 53 Air Bag Tone Warning Indicator Circuit Short to Battery Go To Pinpoint Test D . B1892 53 Air Bag Tone Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test E . B1921 14 Air Bag Diagnostic Monitor Ground Circuit Open Go To Pinpoint Test F . B2292 33 Restraint System - Safety Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test G . B2292 34 Restraint System - Safety Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test G . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2294 24 Restraint System - Curtain Fault (Driver Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2294 25 Restraint System - Curtain Fault (Passenger Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2295 22 Restraint System - Side Air Bag Fault (Driver Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2295 23 Restraint System - Side Air Bag Fault (Passenger Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault (Front Impact Severity Sensor Circuit Fault) Go To Pinpoint Test K . B2296 43 Restraint System - Impact Sensor Fault (Driver Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 45 Restraint System - Impact Sensor Fault (Driver Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 44 Restraint System - Impact Sensor Fault (Passenger Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 46 Restraint System - Impact Sensor Fault (Passenger Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2434 51 Driver Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test L . B2435 51 Driver Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test M . B2438 52 Passenger Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test N . B2439 52 Passenger Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test O . B2477 Continuous Module Configuration Error INSTALL a new RCM. B2691 51 Driver Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test P . B2692 52 Passenger Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test Q . C1414 15 Incorrect Module Design Level Go To Pinpoint Test R . C1947 49 Driver Seat Track Position Sensor Circuit Short to Ground Go To Pinpoint Test S . C1948 49 Driver Seat Track Position Sensor Circuit Resistance Out Of Range Go To Pinpoint Test T . C1981 49 Driver Seat Track Position Sensor Circuit Fault Go To Pinpoint Test U . - - No Communication with the Restraints Control Module Go To Pinpoint Test V . Your best bet have codes checked with a scan tool .
Jan 23, 2017 | Lincoln Cars & Trucks
Orange light keeps coming on randomly on right hand side of dash just above lights the light is square shaped with like ripples for three rows and then on top of the square and two half circles .
Sounds like traction control coming into operation. Ease up on the gas a bit.
There is a great website that lists all the warning lights for most vehicles.
Google
make model warning lights.
May 09, 2016 | Cars & Trucks
A yellow warning light like a wheel spinning. What is it?
This is a traction control light. It seems like your TCS is bad, or has a sensor issue causing the vehicle to retard the acceleration. The car thinks that it is losing traction, so It is automatically trying to compensate
Feb 28, 2013 | Cars & Trucks
Abs light is stays on. The air bag light stays on as well. I have a 2004 Ford exploer sport trac 4x4
Get the fault code.
DTCa LFCb LFC Priority Description B1318 - - Ignition Voltage Below 9 Volts - - 1 RCM Disconnected, Inoperative, or Lost/Low Ignition Feed B1342 24 2 RCM is Faulted B1231 19 3 RCM Crash Data Memory Full B1921 21 4 RCM Bracket Ground Resistance High C1414 29 5 Incorrect Vehicle Identification Code B1887 15 6 Driver Air Bag Circuit Shorted to Ground B1916 15 7 Driver Air Bag Circuit Shorted to Battery or Ignition B1888 16 8 Passenger Air Bag Circuit Shorted to Ground B1925 16 9 Passenger Air Bag Circuit Shorted to Battery or Ignition B1932 32 10 Driver Air Bag Circuit Resistance High B1933 33 11 Passenger Air Bag Circuit Resistance High B1934 34 12 Driver Air Bag Circuit Resistance Low B1935 35 13 Passenger Air Bag Circuit Resistance Low B1901 14 14 Front External Crash Sensor Shorted to Ground B1941 41 15 Front External Crash Sensor Open Circuit or Short to Battery B2444 48 16 Driver Side Crash Sensor Internal Fault B2445 49 17 Passenger Side Crash Sensor Internal Fault B2441 42 18 Driver Side Crash Sensor Mounting Fault B2440 43 19 Passenger Side Crash Sensor Mounting Fault U2017 44 20 Driver Side Crash Sensor Communication Fault U2018 45 21 Passenger Side Crash Sensor Communication Fault B1993 36 22 Driver Side Air Bag Circuit Shorted to Ground B1992 36 24 Driver Side Air Bag Circuit Shorted to Battery or Ignition B1994 36 26 Driver Side Air Bag Circuit Resistance High B1995 36 28 Driver Side Air Bag Circuit Resistance Low B1997 37 23 Passenger Side Air Bag Circuit Shorted to Ground B1996 37 25 Passenger Side Air Bag Circuit Shorted to Battery or Ignition B1998 37 27 Passenger Side Air Bag Circuit Resistance High B1999 37 29 Passenger Side Air Bag Circuit Resistance Low B1892 - 30 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open B1891 - 31 Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition B1869 Tonec 32 Air Bag Indicator Inoperative B1870 Tonec 33 Air Bag Indicator Shorted to Battery - - - No Communication With the Restraints Control Module (RCM)
a DTC: Diagnostic trouble code
b LFC: Lamp fault code, flashed on air bag indicator.
Apr 21, 2011 | 2004 Ford Explorer
HOW TO TURN OFF THE RING TONE OR TURN DOWN THE VOLUME
Press Function and scroll to User setting with the right arrow(Nr 10 and 12 on the right hand side)and press start!Scroll to volume control and press start and u will be able to set it there!Just press start after setting each one you want!Good Luck!
Apr 30, 2010 | Canon FAX-L250
There is a light on the dashboard that I do not
I believe it's the washer fluid light
Here's a list of your dash lights and their meanings
Left
1. Door-ajar warning light
2. Oil pressure warning light
3. Check engine warning light
4. Tour or Sport for the ECS
5. Security indicator
Center Warning Lights
1st space down
Left: 4-wheel steering oil level warning light
Right: Brake warning light
2nd space down:
Left: Anti-lock brake warning light
Right: Active Exhaust Tour indicator
3rd space down
Left: cruise control indicator
Right: cruise control ON indicator
4th space down:
Left: charging system warning light
Right: High-beam indicator
Right Warning Lights
1st down: Not used
2nd down: Seatbelt warning light
3rd down: Washer fluid (2 storage containers)
4th down: Supplemental restraint system (SRS) warning light
Oct 07, 2009 | 1994 Dodge Stealth
BMW 318 SE warning light
I drive a 2000 5series and the only light that sounds similar is the radiator low water warning light. worth a check.
Jan 07, 2009 | 1999 BMW 318 ti
Right hand side lights not working.
Short in any of those slots/lamp holders causes this..accordianman
Dec 15, 2008 | BMW 325 Cars & Trucks
Dishwashers Logo
Top Dishwashers Experts
