Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Lubicating motor - Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
    Problem Solver:
  • 10 Answers
This is a great clipper but the blade can be tricky to reseat. Just pop off the blade using the thumb spring near the bottom of the blade, however do not pop straight off! Instead pull the blade up towards you before removing. This should angle up the metal tongue so it is easy to replace the blade. Next you can lubricate any moving parts but be sure to both remove any excess hair first. Also use only oil made for clippers since other types might evaporate and lead to corrosion.
When you're ready to replace the blade make sure it slides onto the tongue and then to seat it properly turn on the motor and snap into place!
Posted on Mar 13, 2011
Trouble garage door
Disconnect the door so the belt and pulleys will run without a large weight to move. If they move ok, reattach the door and try again but help the door move with your hand. If it moves ok then, the door levers and joints may be too stiff and need lubicating and wiggling until they move freely.
Nov 16, 2013 | Ultra Max Home
Receiving Error Code 1
1) See the calibration software below the hood of your owner manuals for to help to diagnostic.
2) Adjust the speed sensor and tight the connector.
3) Main motor faulty. see the voltage 115 vac, without load.
4) Main motor controller board faulty. See the 115VAC for input coming from Transformer.
5) Test the TRANSFORMER for input voltage and secondary voltage,
6) Power supply output for +5vdc, for input and output.
7) Adjust the deck belt and drive belt.
8) Lubicate the deck belt.and
See the block diagram the I did for people like you. And diagnostic very easy. Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua
Dec 15, 2011 | Proform Exercise & Fitness
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
How do I lubicate my Norditrack T9ci?
You get a tube of lubricant and instructions in the kit at treadmill accessory kit.
May 30, 2010 | Nordic Track NordicTrack T9 ci Treadmill
Need to lubicate
Page 82 of the manual.
Feb 21, 2010 | Singer 3116 Simple
The cooper tube on the back of unit is broke. And there is oil leaking. Can this be fixed?
the oil is lubicant in the coolant. Has to be sucked out/recharged. If was due to viberation of operation, warranty should be 5 years
Dec 19, 2009 | Soleus CFM-40 Dehumidifier
2004 GMC safari rear electric door lock is not working
remove panel, if any, check for loose wires, clean and lubicate
Sep 12, 2009 | 2002 GMC Safari
1991 honda accord a/c blower
replace the blower motor, you can take it out or try to inject wd40 type lubicant into the housing.
Jul 01, 2009 | 1991 Honda Accord
Hello, We purchased a FIMCO sprayer last year, used it twice and stored it indoors. Now the motor will not work. My husband tested it with his meter and power is getting to the motor and past the...
Pull the side cover off the pump of there will be small shaft, turn the shaft it will free it up. You need to make sure that the pump is cleaned out after each use, you can get a cleaning material that you want to run through the hole system, relief valve, spray nozzle etc. it will lubicate everything up. If you did not clean it out it will seeze and you will needs to be freed, chemical will freeze the moto.
Apr 27, 2009 | Garden
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
