RIM BlackBerry Pearl 8120 Cellular Phone Logo
Posted on Mar 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • RIM Master 1,001 Answers
  • Posted on Dec 26, 2016
wwlvictoria
RIM Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603903
Points
6027
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
  • Posted on Mar 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
391859
Points
4742
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
How to pair bluetooth
One device sends the Bluetooth signal. For example, your smartphone can send a Bluetooth signal to play music from the phone on a portable speaker, or you might send it to a wireless earphone to make hands-free phone calls.
The second device receives the Bluetooth signal and plays the sound or picture.
To pair them, first set the receiving device (example: Bluetooth speaker) in "pairing mode". This is usually done by pressing a certain button on the receiving device for 3 or 4 seconds. Next, on your sending device (example: your phone) open the Bluetooth settings and select to search for Bluetooth devices. Your receiving device should appear in the list of available Bluetooth devices. Tap to connect to the receiving device. This may take up to 15 seconds. You should see a message on one or both devices saying "Connected".
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
2answers
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 • Cell Phones
1helpful
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
2answers
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 • Cell Phones
I have an L.G. Shine and cant get the blue tooth to work
The bluetooth of the phone is in the settings of the phone. To get it to work, turn on the phone, then you go to the settings, go to bluetooth and turn it on from there, once it is turned on, then you ensure the device you are trying to pair with is turned on, then you try to send or receive a file from other devices, it will require you to pair the devices up to be able to send or receive files using the bluetooth.
Use a simple pairing passkey to pair the devices up, like 1111 or 0000, that should help.
Hope this was helpful. Thanks for using fixya.
1helpful
2answers
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
2helpful
2answers
Not able to send anythin via bluetooth....!!!
I don't know whether its exactly the solution or not, but I had a similar problem transferring some mp3 files to any cell via bluetooth from my nokia 7210, I tried all combinations of bluetooth settings, but the same message kept appearing-"Sending failed", finally what I did was "Changing the name of the mp3 files" as all those I wanted to send had a bigger name, I cut the name short and there it worked. So, may be in any such case it's advisable to just try this out, it might just work.
14helpful
3answers
Blackberry 8110 - cant receive bluetooth stuff
with a blackberry you have to go to the media player, go to music for music and then hit options receive using bluetooth
1helpful
Connecting my phone to my pc via bluetooth
if your pc and phone has a bluetooth device, just pair those devices ones its paired and connected, on the task bar you will see the bluetooth icon, right click that icon and choose receive file. then send the file from your phone.
Feb 21, 2008 • Cell Phones
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
