Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
My hitachi 42pd6600 is not working,switched it off last night ,this morning its completely dead,checked fuse and lead and they are ok.
  • Hitachi Master
  • 2,098 Answers
Hi Peter,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Mar 11, 2011
I put the tv on standby last night tried to switch on this morning and cannot get anything no lights etc any ideas?
i guess you burnt the power already or check the plug and change the fuse in the plug . see what happens
Jan 13, 2018 | Hitachi Televison & Video
Bought a battery for my 1996 gs300 Lexus last night woke up this morning and everything is dead... Starter alternater and battery checked good the night before
you have a short or something staying on .like a dome lite perhaps some device plugged into a cig lighter socket . if you cant find the problem the only thing you can do is remove positive battery cable each night till you find what is draining the battery when it sits over night . seems like you checked the altenator already .
May 21, 2014 | Cars & Trucks
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Jun 11, 2012 | RCA Televison & Video
No power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Oct 03, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
