Question about Logitech Cordless TrackMan Optical Trackball
A small chip/divot in the ball after it was dropped. Catches on the roller bearings and hangs. Can JUST the Ball be replaced??
  • 604 Answers
You can buy just the ball from the company, but first contact a computer repair shop and ask if they might have one lying around, these devices go bad and they may have some. To buy the ball from the company and pay shipping may be cost prohibitive and you might be better off just replacing the complete unit. one alternative if your handy. get some epoxy (from ACE hardware or etc). make up a small amount of the paste and fill the chip., when it drys (24 hours) sand it smooth and it should work again. the stuff is very hard and I have made repairs with it before on equipment that could not find replacement parts. good luck
Posted on Mar 11, 2011
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
Why does the transmission click when I turn the counter shaft
this indicates either a bit missing from a tooth of a gear, or a failed bearing cage (roller ball bearings) or needle rollers
Some gear box construction use needle rollers running on a solid shaft from one end of the box to the other and some boxes use ball bearings on the ends of the counter shafts. There are needle rollers in the end of the clutch (input shaft) as well
Sep 28, 2014 | Cars & Trucks
Right rear wheel bearing for 89 Ford Probe GT, Replaced 4 times in 30 days.
If you are running tapered bearings then I would say that your problem is over-tightening and will destroy bearings very quickly. Too much or not enough grease will do the same . To properly grease new bearings you have to get the grease between the rollers and under the cage (that steel bit that holds the bearings apart) To do this place a small amount of grease in the palm of your hand and use the open end of the bearing to create a scraping action through the grease . This catches the grease and pushes it between the rollers. Do this action until you see it coming out the small end of the bearing. This is all the grease you need for a properly lubricated bearing. Repeat the process for the other bearing. Reassemble and fit the washer and locknut. Tighten the nut at the same time turning the wheel. When the nut is firm against the bearing but not tight turn the wheel a few more times. Now don't touch the wheel but loosen off the nut then retighten it up until it just touches the bearing. This is a no pre-load no end float situation that is most desirable for tapered roller bearings. Fit the split pin in the hole and open up the pin to catch it in the hole. If the pin hole will not allow this to happen tighten it just enough to get the first available slot to line up to allow the pin in. If you have thrust ball bearings they same method of greasing and adjustment is applicable.
Aug 01, 2013 | Fulton WB750 Wheel Bearing Kits
I have disassembled a three speed transmission from a 1965 6 cyl Mustang. I found a handful of roller bearings in the bottom of the case. I find nowhere they might have come from. Both of the shaft...
These bearings are end of shafts support as rollers can take a higher load than ball type, check both housing,s and the ends all shafts good luck.
Feb 16, 2011 | 1965 Ford Mustang
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
How to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Mar 14, 2010 | Hilti Drills
Is a ball bearing the same as a wheel bearing hub assy , I took my 2001 Dodge Dakota to a repair shop he replaced the front wheel bearing hub assy, when I took my truck home it started making a popping...
????? This vehicle should be equiped with tapered roller bearings. Ball bearinga are out dated and not used since the 60's. No on the hub assembly, The brgs go into the hub and are replaceable as a seperate part.. $ 500.00? This is a mechanic? Do this, jack up the front end of the vehicle and rotate the wheel to determine if there is a proble. Not ant rough or hanging up of ythe wheel while turning it. Then put one hannd on the top and one on the bottom and push and pull. You are now checking for loose bbearings. Any looseness or roughness is a call to have the wheel and hubs pulled and inspected. 500.00? He is trying to get rid of you by quoting an outrages price. If you accept the estimate he is all the more happier for ripping you off. Take it to another shop and say no more than " Please chk the front end and wheel brgs. DSay no more than that and leaave them to their work. They will call you when they need you. Ask for the old parts if you have them replace or repair.. My estimate. 20 to 30.00 in parts and shop time 1.5 hrs. A reputable shop will show you where,why,and how.the process works..
Oct 28, 2009 | 2001 Dodge Dakota
Steps needed to replace front lower ball joint on 1998 vw jetta
these are actually easy to replace on these cars.
there are 3 small bolts that hold the ball joint to the control arm. new ball joints are sold with new hardware, so don't worry if it gets damaged when removing.
mark the postion of the old ball joint. they can be moved slightly on the control arm to change alignment.
the top of the ball joint is clamped into the wheel bearing housing with one large bolt.
I use a very large & dull chisel to spread the clamp on the bearing housing if the top of the ball joint is difficult to pull out of the wheel bearing housing.
Jun 20, 2009 | 1998 Volkswagen Jetta
Ball bearing in brush roller
These can usually be purchased thru a hoover dealer and are not expensive.
Mar 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Logitech Cordless TrackMan Optical Trackball Logo
125 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
