Question about Whirlpool Washing Machines
Hi my whirlpool awo/d 8140 keeps telling me to clean pump where is the pump to clean. thanks
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
SOURCE: Whirlpool AWO/D 4505 Washing Machine
The 'Clean pump' light has come on, on the above washing machine and it will not work. Any idea how to clean the pump or do I need to contact a whirlpool engineer?
Posted on Jun 27, 2010
Master_Tech
  • 770 Answers
SOURCE: washing machine
whats your email i can send you the service manual
Posted on Jul 30, 2008
  • 141 Answers
SOURCE: i have philips whirlpool awo/d 4605 model and its
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Posted on Jan 05, 2010
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
Hi,My whirlpool AWO/D 8140 appears dead there is power going to the machine but there are no lights on. Is this fixable
probably the circuitboard. you should call a household technician to check the machine and if not i'm afraid it will need to be replaced
Aug 13, 2017 | Whirlpool Washing Machines
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
Whirlpool A+A 5kg/1000 AWO/D4305 clean pipe light has come on what shall i do
I think you are wnting to tell the message is " clean pump ". There is no such " clean pipe ". Sir, please reply me for this matter.
Sep 06, 2009 | Whirlpool Washing Machines
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
731 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
