Question about Sebo Automatic X1 Bagged Upright Vacuum
Sebo Vacuum runs intermittently and keeps cutting out and restarting
  • 285 Answers
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Posted on Mar 11, 2011
Sebo x4 cuts out intermittently
May be defective wire(s)
Sep 25, 2017 | Sebo Vacuums
The suction is not working
some machines have a 'safety' built in where if the belt is broken, other items like the lights don't work. Check and replace the belt first. It's also very important to keep the tubes that suck air unclogged, and clean the filters EVERY time you use it
Dec 31, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Hi, I've just had my Sebo X4 back from being repaired (motor was growling so Sebo replaced it FOC under warranty) however, the replacement motor is 1000 watts. I queried this with Sebo, as they c
Watt= volts x amps So what are you losing? Not much really. Should they replace it with the same motor? Possibly, but you got a free motor out of them. To be honest I think you're splitting hairs on this one. The difference in how much cleaning that sebo will do with one motor vs the other is beyond minimal. The aggressive brushes on that vacuum do 95% of the carpet cleaning and both motors will have no problem turning it at sufficient speed. As far as suction goes I'd be amazed if it was even a noticeable difference. That's an amazing vacuum you bought, I wouldn't worry about it and go on with life.
Good Luck
The Vac Dr.
Nov 12, 2012 | Sebo X4 Bagged Upright Vacuum
My sebo cleaner keeps almost cutting out but comes back on again after a couple of seconds. I.ve checked for blockages and changed the bag and filters.
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Oct 07, 2010 | Sebo Vacuums
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Jim
Oct 05, 2010 | Sebo X4 Bagged Upright Vacuum
Machine keeps cutting out intermittenly
My Sebo Air Belt C2 Total. The automatic electric cable wire won't stay out when pulled, it just springs back. When I'm hoovering I have to wrap the wire around the small wheels so that it doesn't shoot back in the machine.
Oct 18, 2009 | Sebo Air Belt C2.1 Bagged Canister Vacuum
My SEBO vacuum cleaner keeps cutting out which seems to suggest an dodgy electrical connection...any ideas ?
If it just cuts out then comes back on after a while, it might be overheating.
Sep 22, 2009 | Sebo Vacuums
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
Looking to buy a new vacuum
We had a Sebo X1 Automatic for 13 years, similar to Riccar but more simplistic, large bags and brilliant for pets (clearing up after 2 rottweilers, 1 westie and a cat). Shop around for Sebo if you are after an upright vacuum - though it uses bags it is far healthier and Sebo have GHI and endless awards for their reliability. Currently Im running a Sebo Felix as a second upright vac in the home , has a much smaller dirt capacity but over the two, I'd say the X range is the best. In the U.S/Canada Sebo are available as are the commercial version which is just as good known as Windsor-Sebo.
Mar 31, 2009 | Vacuums
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
1,351 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
