My LG washing machine is showing fault OE. Can you help?
    Scholar:
  • 106 Answers
OE Error Knowledge Base; http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
You can check the knowledge base first, if not. Your looking at replacing the drain motor, as these are very common to go out.
Posted on Mar 12, 2011
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
Hi I keep getting an error fault of OE, can you tell me what this is
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 11, 2011 | Washing Machines
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
My washing machine is showing a sign oe what can l do lg brand
my washing machine showing a sign OE what should i do
Mar 11, 2011 | Bosch Washing Machines
Washer now shows OE on progess window after i tried to wash bathroom rug. Would not spin/drain excess water and door won't open.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine that has an OE error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | LG WM-2077C Front Load Washer
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
MY LG WASHING MACHINE SHOWS AN ERROR MESSAGE (OE)
LG themselves have some information on this error code..
Nov 23, 2009 | LG WM1814CW Front Load Washer
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
Jan 29, 2009 | Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
