Question about Cell Phones
Nokia E52: after a complete charge using the AC-4U charger, went to disable power-saving mode with a short press of the power button. Pressed it too long and the phone shut down. Now, it won't power up--at least the screen isn't lit. The ******** does come on after one second of power-on button as normal, but no sound or screen display. Plugging a charger in, either through power plug on top or mini-USB on side, changes nothing--stays dark and silent, with only vibrate motor working when power button is held down. Have taken battery and even SIM out for a few minutes, but no change in symptoms. Currently have battery out, hoping to discharge any hold-up cap. Suggestions?
  • bob944 Mar 23, 2011
    I did get two more BP-4L batteries; they behave the same: plenty of power to spin the v.i.b.r.a.t.e (FixYa blocks the word v i b r a t o r, thinking it is a *** toy) motor over and over in response to the power-on button, but the phone does not show any other signs of life, visual or audible.
    The AC-4U charger is the charger that ships with the phone when new. Charging the old or the new batteries with the alternate charging methods Nokia provides--such as the USB port cable--gives the same result: v.i.b.r.a.t.e motor only.
  • 2,069 Answers
The battery could have gone dead, you should try with a different, charged battery first. If it powers, check that you are using the correct charger from nokia.
Regards
Posted on Mar 11, 2011
My Kocaso M736 tablet is not fully turning on. If it is not plugged in, the screen will stay black and won't turn on. If I have it plugged into the charger and press the power button and hold it, the
Sounds like your battery is shot. If it goes to far past dead, it will not power up even plugged in. Go to a battery store/Best Buy etc. and see if they have one you can use to try. Certain battery types can not go under 25% of a charge or they will not charge again correctly and vice versa. Just a short in the dark but hope that fixes your problem
Mar 07, 2014 | Kocaso BRAND NEW M736 7" High Resolution...
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Laptop wont even start to power up when power buttonis pressed the green power light comes on for about 4 to 5 seconds then goes off the same thing happens with battery or power packthe same thinh happens...
Problem may be a simle matter of the battery contacts needing to be adjusted so they make better contact for charging and use. Use a needle and ~GENTLY~ raise contact bars on either laptop or battery.
Jul 18, 2011 | Dell Latitude D610 Notebook
My laptop (hp x9010)is not switching on ,i pressed the reset button but still not responding whats the problem and solution
This could be down to several problems.
Firstly, check that the battery is being charged by the charger and indeed if power is getting to the laptop via the charger. The simplest way is to see if the charger LED light is green. Flashing green indicates that the power is being "spat back".. ie: not completing the circuit and this indicates that the charging circuit on the board may be damaged.
Secondly, is the charger plug tight in the port? A loose plug will not make enough contact (if it is try wiggling it and see if that helps. If it IS loose and works whan wiggling, you will need to get it replaced.
Thrirdly, try removing the battery and AC power, press the on button for 30 seconds, reconnect the Ac adaptor only and see if it then powers up
failing that, it would seem that the main fuse on the motherboard has bloen and you need it replacing
Jan 22, 2011 | HP Computers & Internet
Nokia E52 it's not charging! everytime I plug it in, instead of the "charging screen", it says "not charging", and then "unplug charger to save power" or something along...
This often happens when your battery is not having perfect contact with the terminals and as a result, it prevents the power from your power outlet ot easily flow into the battery and charge it.
The easiest way toi tackle this problem is to follow the following instructions.
1.switch off your phone and remove the battery,
2.Use a dry lintless cloth to clean the battery terminals and the points of the battery that comes in contact with the terminals on the phone.
3.replace all parts and try again.
if this doesn't solve your problem, then your battery could be completely dead and needs replacement but contact a technician first.
hopw this was useful? Please dont hesitate to comment for more information.
Jan 13, 2011 | Nokia E52 Smartphone
My unit is Nokia E52.please help me how to deactivate power saving mode because i can't change my light time-out due to power saving mode active.
As Nokia E52 is the ESSENTIAL MODEL Mobiles, As its in high Range of Applications Used to get it's Visual.
Here are the Fiew tips to DEACTIVATE the Power Saving Mode.
1. First Switch on your Mobile.
2. After completing it's Process, Click the Menu Button.
3. Go to the Settings
4. Settings -> Display Settings
5. Go to the Power Saver Mode Option,
6. Change the Mode of Operation from ON to OFF
7. As Now go to the Screensaver Settings,
Change the Time-Out time to your Favour.(Not Less than 15 Secs)
7. As after this setting is Done, Restart you Mobile Phone
But Kindly Connect your Phone with Nokia PC Suit and Update your Phone to keep your phone upto date of the Latest firmware.
To get the Updater, Click the Link Below
http://www.nokia.com.sg/support/download-software/phone-software-update
Click the Download Button in Update using your PC section, There you can find Nokia Software Updater, Select your Language.
Jan 03, 2011 | Nokia E52 Smartphone
Unable to disable power save mode
Press the power button, the option to disable power save is on that menu.
Nov 04, 2009 | Cell Phones
SANYO MM-5600
If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the back light will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, Sometimes the ones that come with the phone can ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Nov 29, 2007 | Sanyo MM-5600
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
