Question about HTC HD7 Cell Phone
My bluetooth device does not work and also fails. what should I do?
    Sniper:
  • 93 Answers
HI, HAVE YOU TRIED TO RESTORE TO FACTORY SETTING? BUT NOTE WHEN YOU RESTORE, YOU COULD LOSS SOME DATA.
CHEERS
Posted on Mar 11, 2011
Bluetooth won't charge. Red light comes on and then turns off. Bluetooth won't work.
Sounds like the rechargeable battery in the bluetooth device has failed. (Most bluetooth devices do not have batteries that are replaceable.)
May 15, 2015 | AUVIO Bluetooth Headphones
How do I pair my nokia 3109c mobile phone with my motorola h720 bluetooth headset - it just keeps saying "failed" when I try.
Hi Sue Clay,
Please use the following link to access to the user manual of your H720: http://bit.ly/1DyhSmE, on page 5 you can find how to pair the device, if the "failed" message continues, use the instructions on page 13 to reset the device.
Regards,
Lester S.
Motorola Support
Oct 27, 2014 | Motorola Mobility H720 Bluetooth Headset
My samsung s5230 bluetooth is not working
sir in your samsung cellphone the bluetooth device is failed.give to the samsung service center for changing the new bluetooth device..................
Dec 26, 2010 | Samsung SGH-S5230 Cell Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
I have a 1510 but i cant see any bluetooth option on every window and option . is this model have internal blootooth? where & how can i active it?
check device manager if you have bluetooth devices installed. if yes but it has symbols like (?) in the device manager then install the driver. if it has (!) symbols then uninstall then reinstall the driver with the latest one. if the sysmbol is (x) then right click on the device then enable. if all fails then you might not have bluetooth device installed. but if you were able to use this bluetooth few days time then try to do system restore. if fails then replace the bluetooth card if you have one.
Dec 06, 2009 | Dell Computers & Internet
Bluetooth fails to deactivate
the chip of bluetooth works with the smal program on the cellphone.  there are two option. software or chip is broke down. should go to service.
May 29, 2009 | Samsung SGH-D900 Cellular Phone
Problem with bluetooth
My mobile Bluetooth does not connect and it will right me that bluetooth failed
Jul 14, 2008 | Samsung X820 Cellular Phone
Samsung P310 Bluetooth Activation Problem
I too had the same prob!
Here's what u have to do (the method that worked for me!) :-
*Go to Settings>Bluetooth>
*It displays options like 1. Activation, 2. My Devices etc.
Select "My Devices"
*Then select "Search for new devices"
That way it automatically turns the bluetooth on and searches for devices!! (quite odd if u ask me!)
After u have transferred ur stuff, u can deactivate it by using the "Off" option from Activation
Hope this helps u! :)
Feb 20, 2008 | Samsung SGH-P310 Cellular Phone
Motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Oct 31, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Using Wing for internet through macbook pro?
You can connect and synchronize your device with the pc using bluetooth. ON your device tap
1)Start-Program-Active Sync
2) Make sure that Bluetooth on both your device & the computer are turned on and set to visible mode.
3)Tap MENU-CONNECT VIA BLUETOOTH.
goodluck
Jul 25, 2007 | T-Mobile Wing™ Smartphone
HTC HD7 Cell Phone Logo
35 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
