Question about Morphy Richards GBD239H9B Microwave Oven
Morphy Richards Microwave GBD239H9B the light comes on the plate spins but it will not warm up.
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Mar 11, 2011
Where can i get manual for morphy richardscombi microwave.ac925efp
Free Morphy Richards Kitchen Appliance User Manuals ...
kitchen.manualsonline.com/manuals/.../morphy.../morphy_richards_pro...
Morphy Richards Electric Pressure Cooker User Manuals. Get Manuals; Support ...Morphy Richards Hot Beverage Maker User Manuals. Get Manuals; Support
Oct 30, 2015 | Morphy Richards AC925EFP...
My morphy richards microwave ac925egm plate does not turn is there a setting that stops the plate from turn that my kids have put on by mistake or has the oven had it
I'm not familiar with this brand, but does it have a plate that sits on a roller ring? Is the plate sitting in the slots of drive?
Sep 20, 2014 | Morphy Richards Microwave Ovens
DOESNT HEAT UP
If the oven light and carousel lights up when you try to heat water in the oven, then your best bet is the fuse for the microwave oven is open. Unplug the oven, open the case after 30 minutes. Be careful of the capacitors. You will see something like a small plastic casing along one of the wires, usually color white. This can be opened. Usually a spare fuse is alongside, remove the fuse and replace it with exactly the same kind and rating. This fuse is not ordinary. It is about 1/8 inch diameter by 2inches approximately. Be careful that you get exactly the same rating of fuse. When you are done, place the plastic fuse case cover secure in place. Then put back the cover. Be careful that you replace the cover very well back. Be sure that you did not detach the door when you are removing the cover. If you have detached the door, you have a serious problem. Your oven might leak and you will have radiation burns. Place a cup of water inside the oven to test it and run the oven for 30 seconds.
Jan 16, 2014 | Morphy Richards GBD239H9B Microwave Oven
The outer cases is very hot of the microwave is hot
see if there are some device hot such a motor, fan, transformer, magnetron, etc. see the pictorial and use the common sense.
2) test if there are some line to ground, causing this problem see the diagram and test with VOM
God bless you
Jul 16, 2012 | Morphy Richards GBD239H9B Microwave Oven
My morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
May 02, 2012 | Microwave Ovens
The microwave has stopped heating, anything I can try?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ][
Aug 30, 2011 | Morphy Richards GBD239H9B Microwave Oven
Morphy Richards AC925EYG Convection has stopped heating items
Same thing has happened to me. My brother in law seems to think it cant be fixed. Bought it Dec 2008 so no warranty.
Were you able to get anythihng out of morphy richards?
Jan 09, 2010 | Zanussi ZMB30CST Convection Microwave Oven
Morphy Richards GBD239H9B Microwave Oven Logo
418 people viewed this question
Top Morphy Richards Microwave Ovens Experts
William Miller
William Miller
Are you a Morphy Richards Microwave Oven Expert? Answer questions, earn points and help others
