Question about Silver Cross POP Stroller - EBONY
The claspt ( fastner) has broken snap and i need a new 1 do u no where i can purcase 1 from
  • andrea blake Mar 11, 2011
    hi which country are you in?
  • 35 Answers
You can either go back to your retailer or contact silver cross directly here:
Posted on Mar 11, 2011
How to remove brake lever from a 1992yamaha xj600 motorcycle?
Feb 21, 2015 | 1992 Yamaha XJ 600 Diversion S
How to get change tail light bulb
Lift gate up remove the 2 screws on the side of the light housing. The back of the light housing is held in by pin style snap fastner. Two ways 1 grab top and bottom pull hard and fast and hope to pop out both. 2 get a hold of the top and just pop it out turn it out grab and pull (always pull straight or the pins will break)
Nov 11, 2010 | 2005 Mercury Mariner
2005 sunfire pontiac frond door
It is likely the handle or rod came of the lock mechanism. YOu will have to remove all the screws in the door panel and then take a pry bar or huge flat-tipped screwdriver and pry the panel off the door. Then take a look inside to see what doesn't look right. You may see the rod hanging there or it may be lying on the bottom of the door. It should snap back in place, if it doesn't stay in place, then a new little plastic fastner will need to be installed to hold the rod in place.
Dec 24, 2009 | 1997 Pontiac Sunfire
Rdf 50we655 lamp replacement--where is access panel
Solved the replacement problem. Access panel is the entire lower front of the set. Two coin slot fastners, located on the rear down low on the outboard edges are the releases. Having undone those fastners, pull gentley from the outboard edges of the lower front panel. There are big snap fastners that will release as you pull from the bottom, working your way toward the center. Once removed, the cover for the light box is just left of center, held on by two allen or phillips head screws. Remove the screws and pullon the vertical fin on the cover. When it is removed, you can pull on the bulb box, the box will come unplugged and slides out. At this point replace the old box with the new one, and repeat the process in reverse. If you did not buy the box, just the bulb, the internet directions and video are very good. Hope this helps!!
Oct 11, 2009 | Sony Office Equipment & Supplies
How to remove door panel on 2002 dodge caravan
The easiest way is to purchase a door panel removal tool for less than $10. You'll still probably break a couple of the tabs but the job will be much easier. Here's a picture of one:
Sep 29, 2009 | 2002 Dodge Caravan
How do you get the passenger side door panel off so I can replace the mirror?
remove all bolts on panel if you have a newer vehicle than after all fastners both hidden behind plastic snaps and ones that are exposed and the all other side mirror panels are removed it should lift up and then off. older vehicles have plastic pins that snap into little holes 360 around the panel. the newer vehicles have like plastic brakets that rest in rectangular holes to hold the panel in place/... so when all the fastners on the door are taken out then just lift straight up on the panel.
Aug 09, 2009 | 2006 Ford F-150
Help - i cant put the rain cover on my quinny buzz, not sure where to put all the snap fastners?
Hi you put it over the hood then it covers the whole pram or you can just use the zip part & zip it onto the hood. if you use it whole it is easier then you can un-zip it if you need to get to baby.
Mar 26, 2009 | Quinny BUZZ 3 Jogger
1991 buick park ave. ign. barell wire broke
i had same problem with a broken white need to go to dealer with you old key to match that chip with new keys and purcase a ignition switch at the same time
Feb 01, 2009 | 1991 Buick Park Avenue
Remove hood insulator blanket
carefully pry the black plastic fastners holding blanket away from hood. these fastners snap into a bracket attached to the hood replace by inserting into the original hole
Dec 30, 2008 | 2004 Cadillac SRX
Silver Cross POP Stroller - EBONY Logo
203 people viewed this question
Top Silver Cross Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Are you a Silver Cross Baby Gear Expert? Answer questions, earn points and help others
