Question about Gateway GT4022 PC Desktop
Noisy fan The fan is always running at the highest speed, and I was wondering if the speed could be controlled?
    Problem Solver:
  • 10 Answers
The fans are controlled by the bios, There is a temp sensor that tells the bios the temprature of 1. The Proccessor, and 2. the board. This all depends on the options of your board ofcourse. When the temp sensor says it getting warm, the fan RPM's are increased to push more air. If you replace one of these fans, make sure it has 3 leads. 2 are for power and one is the RPM sensor that tell the bios if it's running or not. On some of the old motherboards you could set the setting by going in to the bios. I beleive they are all locked now but you can still see them to check if they are running or not, or if its getting hot. You might want to check to see if its getting hot. if it is, move it to a cooler location and check again.
Posted on Sep 04, 2008
The blower fan cuts out intermitently regardless of fan speed when I go over a bump or take a corner. The dash had been removed to replace the evaporator and this is when the problem started. When the fan...
From what you said I would think you have a bad/loose connection. I have never had to change the fan resistor but from what I under stand usually when the resistor is bad the fan only run with the fan speed on the highest setting. If the fan quits working try putting the fan on the highest speed setting, see if fan starts working. Sorry but that all I got for now.
Sep 10, 2017 | 1999 Buick Century
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Aug 15, 2009 | 2002 Honda Odyssey
2004 elantra heater control only operates at #4 setting
If # 4 is the highest fan setting it might be the resistor pack that controls the fan speeds.For each speed increase the fan switch takes a resistor out of the resistor loop The highest speed is a direct connection to the battery. The switch is usually located very close to the fan since it gets quite hot and needs to be cooled by the fan.It is also generaly accessible from under the hood,but not always.Sometimes it is under the dash Hope this helps.
Dec 08, 2008 | 2004 Hyundai Elantra
My hp pavilion a6110n product nogg781aa .Has anoisy cooling fan .How do I chang it.
If it's the processor fan that's noisy you can purchase a replacement. The fan and heatsink are normally a complete assembly you can find from many vendors online. This computer has a type AM2 socket; you need to make sure to get a cooling fan for that type. Be sure the replacement will fit into the same space as the original.
If it's the power supply fan thats loud, there may be a couple of possible causes. It may just be a noisy fan, in which case you can replace the power supply. Make sure to get one that has at least the same power rating as the original. Or the fan may be running at its maximum speed. I don't know about this computer in particular, but many computers control the fan speed depending on how hot the processor is (determined by sensors built into the main board). If the fan is running at its top speed, it can be quite noisy. This might be due to a defective power supply or problems with the fan control on the system board
Nov 19, 2008 | Computers & Internet
Ceiling fan only running at highest speed
First, change the battery.  Second, turn off the power to the fan at the wall switch, if still installed.  If this doesn't fix it, it is probably dead.  Bring it back to Home Depot.  There may be a product bulletin.
Nov 14, 2008 | Dryers
Very noisy operation
Yes....this will throw than fan unit out of balance almost the same way the tires on your car get out of balance. The wobble effect at high speed makes tons of noise.
Oct 05, 2008 | Kitchen Ranges
Gateway GT4022 PC Desktop Logo
124 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
