Question about RCA L32WD12 32 in. LCD HDTV
Well i have a new fluid lcd tv it turns on but it's a black screen but their is sound (music, t.v. shows, ect.) what do yuu think the problem is??
    New Friend:
  • 3 Answers
How do you remove a capacitor
Posted on May 14, 2016
  • RCA Master
  • 2,098 Answers
Hi ,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 11, 2011
TV SYMBOL COMES ON TV GOES BLACK NO SOUND OR ANYTHING HOW TO REPAIR THIS
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the ...the the tv turns on but there is no picture or sound and I can't seem to fix it the .... +tbones11234 I have the same on myHisense 55" TV,what did you ... The problem is when i turned it on it shows on the screen the sony logo three times then its ...
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Click Here to BUY TV REPAIR P... ... I Have a Hisense Tv in My Screen Is Not Working Right The brightness is ... Hi my TV shows the picture for a moment and then goes .... here the sounds but you cant see nothing and a sanyo flat screene.
Jan 16, 2016 | Hisense Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Philips 40" LCD No video
probably,did you have a look for bad caps?
make sure all the cables are housed correctly ect
Mar 16, 2013 | Philips 40PFL5505DF7 40 in LCD TV
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Hi - got a Sharp Aquos LC32AD5E, whilst watching the screen suddenly went white then black, and now stays black. Sound is still there - but absolutely nothing on the screen. I have checked all the...
you can try in a dark room turning it on and see if you can see just a hint of light coming on the screen
its most likley going into a shut down
it could be a power supply or a inverter board issue
or even a lcd display driver board
you will need to find a good servicer in your area to help you with this
and you might try calling sharp and asking if they can offer some assistance with this concidering its age ect
Oct 22, 2009 | Sharp LC32AD5E 32 in. LCD TV
SAMSUNG LCD TV (broken high voltage inverter?)
Sometimes a TV screen will illuminate for a moment when first turned on and then go black. Sound will be OK. Check electrolytic capacitors in low voltage power supply. There will be 2 to 4 around 1000 to 2200ufd. Inspect for caps that look like the tops are swollen or are near sources of heat. What happens is the inverters that illuminate the screen draw a lot of current when the TV is first turned on. Power supply cannot supply the amount of current needed with defective caps. Inverters will then shutdown and not try to restart until TS is turned off then back on. Checking output voltages will look normal when measured with this symptom. Caps are cheap and easy to replace.
Sep 14, 2017 | Samsung Televison & Video
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
RCA L32WD12 32 in. LCD HDTV Logo
303 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
