Question about Panasonic Office Equipment & Supplies
Panasonic kx-ft 934 How can I receive the fax document automatically and also receive the phone call with the same fax machine?
5 Suggested Answers
  • 33 Answers
SOURCE: KX-FL511 Panasonic Fax machine will not receive document
Try going through menu and turn ECM to no or invalid also try adsl filter on incoming line
Posted on Mar 05, 2008
SOURCE: panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Posted on Apr 25, 2008
leroyal
  • 2120 Answers
SOURCE: Panasonic KX-FP153 Copy too dark
Try unplugging the power cord and re-plugging. It sounds like your scanner assembly is going bad.
Posted on Sep 26, 2008
SOURCE: How to use Panasonic KX - FT 67 as an answering machine
hello ,
i am ali , from iran , tehran .
if the fax in memory and paper jamed , what i do clean fax in memory & reset the memory ?
ali_seyedein@yahoo.com
Posted on Aug 08, 2010
How can I change/decrease the baud rate?
The Modem speed or baud selection from highest to lowest is done automatically.
? Modem speed*1: 33,600 / 31,200 / 28,800 / 26,400 / 24,000 / 21,600 / 19,200 / 16,800 / 14,400 / 12,000 / 9,600 / 7,200 / 4,800 / 2,400 bps; Automatic Fallback
see page 84 of 96
ftp://ftp.panasonic.com/faxmachine/om/kx-mb271_en_om.pdf
or click on
5 in 1 Multifunction Office Machine
You should consider .....
2.10 Configuring the unit to access the LAN (KX-MB781 only) You can print documents, scan documents, receive faxes or send faxes using a computer on the LAN. To enable these features, you need to set the IP address,
Mar 22, 2016 | Panasonic KX-MB781 All-In-One Laser...
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
Require user manual for panasonic fax model KX FT 77
Jan 06, 2011 | Office Equipment & Supplies
Fax memory says full. how do you get them(Panasonic KX-FG2451)I haven't been able to receive faxes, don't know if this would effect it.
The memory is full of received documents due to a
lack of recording paper, a lack of ink film or a
recording paper jam. Install paper (page 13), install
ink film (page 11) or remove the jammed paper
(page 63).
the entire manual here http://service.us.panasonic.com/OPERMANPDF/KXFG2451.PDF#page=53
Apr 17, 2009 | Panasonic KX-FG2451 Fax
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: http://www.brother-usa.com/Fax/ModelDetail/2/FAX2840/Overview is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
We can send fax but can't receive...new fax line, old fax machine...panasonic kx-fc195
hi zebaron,
check your ink film maybe its empty, check the receiving mode if its on automatic mode, if its on manual mode you have to press the start button to start receiving fax.
hope this help....
Jul 24, 2008 | Panasonic Office Equipment & Supplies
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Feb 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
104 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
