Question about Samsung BX2450 LCD Monitor
How do i change the angle on the hole screen?
  • 746 Answers
There are you have two options, first with short key Ctrl + Alt+ arrow keys as you want to move.
Second option you have, right click on the desktop and the go to property now click on settings and then advance now you have an option of monitor and now there are 4 options available for rotation.
Best of Luck
Posted on Mar 11, 2011
  • Shahzad  Waseem Akbar
    Shahzad Waseem Akbar Mar 11, 2011
    Please rate my answer as you find excellent or good and if possible please let me chance for testimonial.
    Thanks
Vegetables/fruits getting wet in drawers. No air flow felt in refrigerator
change the angle of the refrigerator so its a little higher on the door side, if wet in bottom the angle is wrong so its not dripping into the drain hole at the back.
Jul 14, 2017 | Refrigerators
Tip
All purpose presentation easel a DIY project
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
on Jan 29, 2014 | Office Equipment & Supplies
How to change from degrees to radian mode casio fx-cg10
In Run>Mat screen press SHIFT MODE to enter the setup screen. Scroll down to the line Angle. Press F2:Rad to set angle unit to radian, See Screen capture below.
Jul 06, 2014 | Casio FX-300MS Calculator
Finding radium mode on FX.........OG
You probably mean Radian mode. (the Radium is a radioactive chemical element, with symbol Ra on the Periodic table of the elements).
To set angle unit to radians, Go to the RUN screen.Press SHIFT MODE to enter SetUp. Scroll down to line ANGLE; Highlight the line and press F2 to activate the TAB RAD on the screen. Angle unit will be set to radians, until you decide to change it again.
Oct 01, 2011 | Casio FX-9750GPlus Calculator
How do you change the angle mode?
Press SHIFT [SETUP] to bring up the setup screen. Move down to the "Angle" line, then select the desired angle mode. Press EXIT to exit the setup screen.
Jan 22, 2011 | Casio FX9750GII Graphic Calculator
How do i change a disc on a angle grinder
There is a small button that locks out the shaft (where the disk attaches). You will need to push and hold down the button while you use the wrench provided to remove the retaining screw (there should be 4 holes in the retaining screw). It is a standard lefty loosy, righty tight. Good luck
May 21, 2010 | Garden
Can I change the angle of my viewsonic screen
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
May 09, 2010 | ViewSonic VA1930WM LCD Monitor
My CGS is messed up , it has light coloured particles on the walls and on the ground , and the colour changes when i look them from another angle EXAMPLE : Map insurrection the hole between the houses is...
Try these:
VIDEO->ADVANCED SETTINGS->PIXEL PER LIGHTING OFF.
VIDEO->ADVANCED SETTINGS->VOLUMETRIC SHADOWS OFF
VIDEO->ADVANCED SETTINGS->FULL SCREEN POST PROCESSING OFF.
Apr 28, 2010 | Eidos Interactive Conflict: Global Storm
Cd drive has disk in it and wont open
Look closely on the face plate and around the face plate of the CD drive. (better to have good flash light/Torch while doing this). Close to the eject button (Or around that area) there will be a very small hole (pin hole). Switch off your computer if it is powered. Push a needle or a safety pin into this hole. Take care to push it in straight (not angled). If it does not open in the first attempt repeat changing the angle slightly. May take 3 or 4 tries. But you can definitely get it opened.
Jan 27, 2010 | Computers & Internet
Samsung BX2450 LCD Monitor Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
