This application has failed to start because mss32.dll was not found
    Brigadier General:
  • 8,909 Answers
I would download and run the registry utility from iobit.com
It is freeware and works then run CHKDSK/F.
Hope that helps
Posted on Mar 11, 2011
Mss32.dll missing on my pc
There are several different ways that mss32.dll errors can show up on your computer. Here are some of the more common ways that you might see mss32.dll errors:
  • "Mss32.dll Not Found"
  • "This application failed to start because mss32.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\mss32.dll"
  • "The file mss32.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: mss32.dll. Please install [APPLICATION] again."
Mss32.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the mss32.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Mss32.dll Errors Mss32.dll errors are caused by situations that lead to the removal or corruption of the mss32.dll file.
In some cases, mss32.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Mss32.dll Errors Important: Do not download mss32.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of mss32.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the mss32.dll error.
  1. Restore mss32.dll from the Recycle Bin: The easiest possible cause of a "missing" mss32.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted mss32.dll but you've already emptied the Recycle Bin, you may be able to recover mss32.dll with a free file recovery program.
    Important:Recovering a deleted copy of mss32.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system: Some mss32.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the mss32.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes: If you suspect that the mss32.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the mss32.dll file: If the mss32.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the mss32.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to mss32.dll. If, for example, you're receiving a "The file mss32.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The mss32.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version: if mss32.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command: to replace a missing or corrupt copy of the mss32.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates: Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The mss32.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive: I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause mss32.dll errors as they fail.
    Note: If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows: If the individual mss32.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair mss32.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid mss32.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows: A clean install of Windows will erase everything from thehard driveand install a fresh copy of Windows. If none of the steps above correct the mss32.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the mss32.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any mss32.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To The mss32.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Still Having Mss32.dll Issues? Let a community of computer support enthusiasts help out! Post the details of your mss32.dll issue in the PC Support Forum. Be sure to let us know the exact mss32.dll error message that you're seeing and what steps, if any, you've already taken to fix the problem.
May 28, 2012 | MSI 645 Combo-L Motherboard
Missing mss32.dll from computer in alone in the dark the new nightmare
Hey,
you can download this dll file from the following link
http://www.dll-files.com/mss32.zip?0WEkSBULeV
you can put this DLL file in the directory where you installed the game. and also in System32 directory C:\Windows\System32
Hope this helps
Cheers!
Feb 05, 2012 | Infogrames Alone In The Dark 4: The...
The procedure entry point_AIL_waveOutOpen@16 could not be located in the dynamic link library Mss32.dll
http://blog.fix4dll.com/fixing-the-mss32-dll-is-missing-error-in-call-of-duty-4/
backup old mss32.dll file first by renaming it in system folder where it lives in hard drive then replace file with the new mss32.dll file
yuotube also has some videos on this
Jan 04, 2012 | Microsoft Video Game Consoles & Games
Missing mss32.dll, im using windows 7 ultimate
MSS32.dll is used quote commonly in various games. A fair number of games rely on Windows having this dll file already installed to an indexed folder such as c:\windows or c:\windows\system32. If you are missing this file you should try reinstalling the game first as there are multiple versions of it - my online research shows 3 distinct versions for games like GTA3/4, Zoo Tycoon, and Counter Strike. It also appears it might be used for some graphics programs.
If reinstalling the program that is giving you this error you might try downloading a common version of the DLL file from http://www.dll-files.com/dllindex/dll-files.shtml?mss32. You should first try putting the file in the 2 folders mentioned above, then start putting it in the folder with the program that is claiming the file is missing (for instance: C:\Program Files\Valve\Steam\SteamApps\<account name>\counter-strike source\bin).
I hope this helps!
Mar 16, 2011 | Microsoft Windows 7 Ultimate for PC
How to install mss32.dll for igi 2 ?
i got this error while running the igi2 game after copying the mss32.dll file to system32 folder."the procedure entry point_AIL_set_3D_sample_distances@12could not be located in the dynamic link library mss32.dll."please help me with this
Dec 11, 2010 | Computers & Internet
"Application has failed to start because wpcap.dll
You need to uninstall the offending program and reload it, and that should resolve the issue. BACKUP FIRST.
Dec 05, 2010 | Microsoft Computers & Internet
Mss32.dll error...unable to play? When I try to play this game Grand Theft Auto Vice City I always come across some error that is related to the "mss32.dll"...any idea how to get rid of it?
hi,
http://www.fix-all-dll-errors.com/mss32.dll/
Visit this site and click the "Fix dll errors now" button.
Just download the program and your prob will be fixed...no
need to run the scan...
Nov 30, 2010 | Computers & Internet
I installed IGI 2 on my pc , now wenever i run it , it says that "file mss32.dll" was not found. what shuld i do plz help.
It's a miles sound system file, get it here and put it in the
windows system32 folder, reboot and the game should run.
Aug 06, 2010 | Video Game Consoles & Games
Sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
