Want user manual for Junkers Hydropower Plus water heater wtd 11 kg 23/31 English version
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: service kit for junkers wr
www.parts-center.it/Documents%5CRicambi%5Cjunkers.pdf
Posted on May 28, 2008
Is the junkers WR 11 Gas water heater ok for outside mounting
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Dec 04, 2014 | Water Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Junkers WR11 Water Heater Keeps Switching Off
Do NOT disconnect anything. Has the unit been maintained, cleaned and serviced? There may be a limit switch malfunctioning. Your safest bet is to have it checked out my someone who knows and is familiar with the unit you have, could be simple, but be safe and have it looked at.
May 27, 2014 | Water Heaters
Siemens KG 36 NVL 31 Manual
manual at below link
http://www.mediafire.com/view/2yjlpgxlf6glj56/90008289454.pdf
May 25, 2014 | Siemens Refrigerators
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
I need an english manual for Junkers FR100 Thermostat Model Serial No 7719002911
Go to Worcester-Bosch.co.uk
Go to "heating" -- Europe then United Kingdom.
Select a gas boiler in the lower selction and click on FR110 ( the nearest to the FR100 that you will get)
You can also see the video
R Jarvis
Jan 11, 2011 | Heating & Cooling
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Heating & Cooling Logo
730 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
