Question about Sharp AR-5316 Advanced Digital Imager Copier
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
    President:
  • 2,072 Answers
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Posted on Mar 12, 2011
Get a serial key for a sharp print ar 122en
serial numbers of all Sharp Copiers are located on the rear right-hand side of the copier , on a silver sticker
Feb 23, 2015 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Photo copier displays H and 4 and all the buttons are inactive
Hi:
H 4 is a fuser related error code. Try getting into the service mode by pressing these keys in quick succession # * Clr * the enter 14 and press start. Shut off copier and turn back on and see if it comes to a ready state.
Good Luck
Andrew
Oct 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp Ar 5320E Xerox machine having A problem to start & when machine switch on showing a massage L 4 on machine screen what is the problem
Check the Main motor and the Flat cable..... Put this Simulation also,We can Found it the main motor working condition or not. Press # key then press interupt key and then press c key then again press interupt key, its all enter to very fast.then enter 25 and press START BUTTON and then press 1 button and again START button. Now the Main motor will run.if it is not run the main motor in damage condition.
Jun 30, 2011 | Sharp AR-5320 Black and White Copier
How to reset sharp ar 122en
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Dec 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-287 reset machine after doing 160K maintenance kit ?
press P Interupt C interupt to enter simulation Press 24 & press start button,
Press 4 & enter start button.
Execute and press CA to exit
Jul 03, 2009 | Sharp AR-168D Black and White Copier
All buttons not function and cntiniosly showing 4 and H
You have fuser problem, try reset by pressing [#] [interrupt] [c] [interrupt] [1] [4] [start]. The machine will goes off and on again, if the problem persists you should replace the fuser lamp
Mar 30, 2009 | Sharp SF 2020 Copier
My copier sharp AR-5320E is showing number 4 and letter H on the display thereby making intructing the copier impossible.
H4 is a fuser problem, normally a reset will cure, to reset press these buttons
#, interupt, cancel (c), inturrupt. Display should say 'enter simulation'
enter 14, start, execute.
Switch off then on and it should work
Cheers
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
