Hey i have a verbatim 1tb hdd and it worked fine up to the point that windows did not recognise it anymore stating error type 43.
  • 27,725 Answers
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
also you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Posted on Mar 11, 2011
Verbatim customer service
MACs does not recognise windows NTFS format. So backup the data (if exist) and format drive to FAT32 or ExFAT.
Jul 31, 2014 | Verbatim SmartDisk USB1TB 1 Terabyte 1TB...
Am having problem my Verbatim Usb 1 tb is not recognising in any port of my PC
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or:
if you can see your usb but its not working
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 13, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
Hi i have a verbatim usb harddisk whit 1tb and the usb is 2.0 but my laptop can't find the device and my windows is xp sow can jou help me greetings Zicko hoek
If your drive came with any drivers be sure to install them.
Also note that the Store N Go 97538 is a USB 3.0 HDD. You will require a USB 3.0 port in order to use it.
More info here: http://www.verbatim.com/index/support.php?lang_id=1&cat=9&action=supportitems&pid=5391
Feb 28, 2011 | Verbatim 1TB PRTBL USB 12.5MM-3.0 2.5...
It got formatted to NTFS and I lost everything...Can I get back to original Fat32 and restore files?
The is a very good program called Filescavenger which will recover files from your disk. I know I have used it and on a verbatim 1TB. The problem I have is that my Verbatim 1TB Model53018 keeps losing its visibility in windows and I have to recover all the files and transfering to another disk!!! Its just bollocks and I won't be buying another one of these **** things. Pay more and get a reliable disk. If Verbatim want to send me a fix... feel free and I might take down this comment. steve@bar-telly.com
Dec 11, 2010 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
Toshiba 1tb external HDD that works fine on TV not on PC anymore
Try using it on another computer. If it doesn't work the drive may be bad.
Mar 14, 2010 | Western Digital My Book Essential Edition...
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
Dec 14, 2009 | Computers & Internet
Verbatim hard drive wont turn on
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
Oct 07, 2009 | Verbatim VER95327 USB Hard Drive
1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Aug 08, 2009 | Verbatim VER95327 USB Hard Drive
Maxtor Diamondmax plus 9 HDD Error on boot up
Maxtor were taken over by seagate some time ago - try downloading and running the Seagate diagnostic tools "SeaTools"
http://www.seagate.com/gb/en/support/downloads/seatools
Jul 23, 2017 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
