My rh397d comes up with the msg 'lack of space' when setting timer recording; disc has loads of space. Have been advised to reformat hdd and to save contents by copying to pc. How do I connect to pc? Manual does not say how.
    Brigadier General:
  • 8,909 Answers
If the manual doesn't mention copying to pc, then you probably can't.
What mode are you recording? If you select high definition then it will require a much larger space than a lower definition recording.
Posted on Mar 11, 2011
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
On the Library section of the DT16300 I have approx 8.5 hours of saved programmes yet the display says there is only 18% of disc space left! out of 60 hours recording time?.
After Re-loading the Freeview Channels on 30th Sept, the disc space was nearly full on The Thomson DT16300. Go to Set up in the Menu, choose 'Personal Favourites' this will bring up all the stored Channels, For some reason a lot of the Channels are marked 'ON' each one takes up disc space. De-select every one, the channels stay in the recorder but release disc space. I now have 86% free. Trevor Rushton
Oct 02, 2009 | Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
DVD Record wont finalize - LG RH397D
Have you changed brand of disks? Sometime different brands give different results.
Aug 08, 2009 | LG DR787T DVD Recorder
After I reformat my LG HDD video recorder to give me more space, it only clears a tiny portion. How do I clear the whole recorder? I am going to HDD format, and reformatting. Thanks
Do you mean it always shows 10Gb less space than the capacity of the drive. ie only shows 150Gb but you have a 160Gb drive? The reason for this is that it has 10Gb reserved for the buffer of the pause/rewind live TV.
Cheers,
Keith
May 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
Recorded onto my lg rh397d/rh399d, want to copy to dvd
You need to read page 37 "Dubbing a title"
Select the title you want to record and select the Dubbing option.
Apr 06, 2009 | LG Televison & Video
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
michaelz@resourceinternational.com
Oct 18, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Hdd
The drive may be damaged physically and is setting the remaining portions of the disc as bad sectors. If this is the case you need to replace your hard drive immediately. If the space is unpartitioned you can do this through windows using a program called partition magic. You can also reformat the drive using a windows cd and it can reformat the drive to 80 gigs (assuming the disc does not have bad sectors).
Aug 06, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
