SOURCE: Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time S Ranson
SOURCE: won't print black, won't clean
You should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridges are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work if it's just a clogging of black nozzles.. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
If it doesn't work after that, then the printhead is dead, and here Canon tertminated you because a printhead is more expensive as the whole printer.
So kiss your printer good bye and get a new one, but at least this time get one that uses cartridges with printhead ON THE CARTRIDGE (like HP and Lexmark) or, if you are in love with Canon, take one that uses the cartridges PGI-5 for black and CLI-8 for color, they also have sepparate printhead from cartridge but it seams they are more durable. And easy to refill, as well!
Hope it helped you in any way!
Rate this solution please. Thx.
SOURCE: Cannon MP 830 Print Issue
sounds like your print drivers on computer are corrupted..try this link for new ones(you may need to completely uninstall the old ones, first, though).
SOURCE: all colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
SOURCE: printing blank paper
try a few things, your printer maintenance my need to be adjusted, such as settings. i have one at work and i hate it, canon printers are so non-user friendly. do you have both a black and a color cartridge in it, if so you will have to tell it in the maintenance settings, if you only have one or the other installed you have to put both in it wont print with only one cartridge. if you just bought it and still have everything that it came with...take it back and buy a lexmark.
