Question about Whirlpool Dishwashers
My whirlpool ADP4601 dishwasher will not drain the water, what should I do to clear it? I opened the door and the filter was flouting in the water I have baled the water out replaced the filter and tried again but the watre will not drain away
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
TJBENGR
  • 121 Answers
SOURCE: Dishwater won't stop trying to drain even when door is opened
The drain valve is stuck open. This is electrically operated, but may have some debris inhibiting movement. If you can physically move it (with the power off) this should repair the problem.
Posted on Apr 21, 2008
  • 9 Answers
SOURCE: I have a fully integrated
hi casey
with my experience with d/w i found that if you pull apart the inside were the blades are there are round plates that require cleaning and there might be something under the plates.goodluck
Posted on Jun 26, 2008
ngafm
  • 166 Answers
SOURCE: Whirlpool quiet partnerII dishwasher
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
That unit has a stainless steel soft food disposer built in to it!
That should not be the problem!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 05, 2008
Dwf 415 dishwasher, overfills with water
gee a whirlpool doing that
check the user manual
the control board failure
water level shut off sensor faulty
water pump failure
check for drain out blockages
http://lastmanuals.com/manual/WHIRLPOOL/DWF-415-W
Oct 13, 2016 | Dishwashers
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Water will not drain after completion
Check the bottom of the dishwasher (where the water drains to) and check there's nothing blocking it? Maybe give the filter a rinse to clear it.
Apr 24, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher model DU92OQWDBO does not drain water and flapper door for detergent did not open during cycle
My Whirlpool dishwasher stop draining the water.
What do you thing is the problem? Pump?
Thanks, Henry
Jul 01, 2010 | Whirlpool Dishwashers
Adp4601 taking three hours to complete cycle - suggestions as to why
Check your hot water temperature. Water should be 120 degrees and if not, the dishwasher has to heat it before it contunues on its cycle. I tested an old Bosch in my cold garage with cold water and it took an hour to get to the first drain cycle.
Hope this helps! Ken
Dec 13, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
F8 Error
F8 code means that washer has not emptied out fully. Open the door,empty water manually, clear the filters and the drains. Close the door and then hold the start button,until it will restart. Good luck !
Mar 27, 2007 | Whirlpool 24 in. ADG7952 Built-in...
Dishwashers Logo
170 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
