Question about Car Audio & Video
My RadioMobile RM7505MP3 doesn't come on straight away. I have to wait about 20 minutes, but other tha last two days it hasn't worked at all.
2 Suggested Answers
steve_e_uk
  • 1675 Answers
SOURCE: Motor started tapping loudly as if there was no
hi this could be due to your hydraulic tappets, these will start to rattle if the oil has been low at some stage and the oil was to thin this normally sounds worse in the mornings on first start and gets quieter as the day goes on or disappears altogether, what you could do, is use an engine flush, put it in the engine and run it for a period of time, then empty the oil and refill with a thicker grade oil and see how that goes..hope this helps
Posted on Feb 24, 2010
Tip
Heating up your car
It seems simple, but you can make a big difference by turning off your radio, wipers, climate control, all of those accessories, when you start the car. Most of the wear on the engine happens when you start the car, and by turning off those accessories, your engine doesn’t have to work as hard when starting.
Another thing people do is revving the engine in the winter. This actually doesn’t help “warm up” the car. Although it does technically make the engine hotter, it’s not the kind of “warming up” that you want. Revving your engine in the winter causes extreme temperature changes right away, which is actually the opposite of what you want. When you start the car, the oil hasn’t yet worked its way through the system, so the engine is working without lubricant. The right way to do it is just let the car sit and idle for about 30 seconds to a minute at the least.
on May 03, 2010 | Ford Explorer Cars & Trucks
What is the correct tension of the head bolts in a 1.3 Sierra
must provide year,still,when u buy the joint it must be provided with instructions,may have more than tension,is the order of tidining,u can have degrees and sequvence like wait 10 minutes between steps,run 1/2 hour before last step ,replace head bolts everytime u replace head joint etc...
ex:ford sierra 1.3
1983-1987
Torx type bolts
use new bolts,oiled
steps:
1.35-40nm
2.70-75nm
3.let it rest at least 5 minutes
4.Final 90?
Star type bolts can reuse
steps:
1.40-55nm
2.50-70nm
3.rest it at least 20 minutes
4.Final 73-83nm
dnt forget good practice clean,verify head straight...etc
best regards
Oct 28, 2014 | Cars & Trucks
I go to the store. Turn truck off. Go inside and come back outside and the truck won't start. Wait about 20 minutes and truck starts right up. This has happend 3 times in the last week. This morni
usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Apr 13, 2013 | Ford F-150 Cars & Trucks
I have a 93 Dodge Colt 1.5 liter engine. I've noticed in the last month or so after it starts that the idle seems to go high and take 15 or 20 seconds to get back down to normal. Two days ago I went to the...
Its probably your computer. Had the same thing happen to me about ten years back. About 500 dollars. better off finding one on ebay or at a junk yard.
Aug 09, 2010 | 1993 Dodge Colt
2000 VW Cabrio Engine Problems!!
Either you threw a belt or the water pump isnt not circulating. You can drive to the shop. Just becareful. When you see it getting hot shut er down and let er cool. If you get it too hot you could cook the motor.
May 26, 2009 | 2000 Volkswagen Cabrio
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
