Question about Panasonic Televison & Video
I have toshiba tv 40PW03 the tube that has been replaced is of panasonic therefore how do i set the colour
  • 1,238 Answers
You can reset or adjust the color by using a remote control then press the menu the settings will appear on your screen and then go to the color..after that press enter button in the color settings and you can adjust the color by pressing volume + to increase and volume - to decrease thank you
Posted on Mar 11, 2011
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Sep 13, 2011 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
Picture is distorted......bowes inward. Colour is
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2011 | Sony KP-57WS500 57" Rear Projection...
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
We have a panasonic colour television- The picture is very dull. we can't see the faces clearly and the title word also not readable.
The picture tube in the set has lost the capacity to produce a decent display, over the years the picture tube builds up a lot of crud in the guns and blocks the emission that controls the quality of the picture. There is an instrument that will burn away the coating, so more emission material is exposed, but this approach is very short lived and back to where you were if not worse. In order to fix this you will need a new picture tube and the cost would prohibited. I suggest replacing it in favor of a new one.
Feb 10, 2011 | Panasonic Televison & Video
Tv with humming sound but no picture.how to resolve
This Means Your Picture Tube Has Went Out Therefore You Need A New Picture Tube
May 29, 2009 | Panasonic Televison & Video
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Feb 23, 2009 | Toshiba 42H81 42" Rear Projection...
Set up an a Panasonic TZ-20L3Z
Press MENU button, select PRESET and then , select MANUAL PROGRAM and SEARCH, when search completed the program stops. Give the channel and store.
Aug 19, 2007 | Toshiba 27A34 27" TV
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
