Question about Panasonic Lumix DMC-ZS3 Digital Camera
The Lens does not go back in when I turn the camera off. when I turn it on again it goes in and right away out again. And it is impossible to focus if I want to take a picture. What can I do?
    Novelist:
  • 147 Answers
This is due to a lens error of some sort.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
My 50 mm 1.4 won't focus on closer objects only far away now after my mom dropped my camera. What can be done? Is it most likely broken?
yes thats a fair bet,,, it could only be the lens that took the brunt of the smack it had and its now jamming when you try to focus up on close ups,,,
try a difrent 50mm lens on it and find out if im right
Oct 17, 2009 | Canon Normal EF 50mm f/1.4 USM Autofocus...
Same exact thing......My mom thinks it needs a new battery.
Hi!
It sounds like your camera lens focus is stuck - could be sand or something in the focus gears - that's the weak spot of these lens. If you can't open the lens and check your lens focus gears yourself, you should contact your local Olympus service center or other camera service center. You can contact me too at toms.safranovs@gmail.com and I can give you a good price.
Hope this helps!
Tom
Jul 29, 2009 | Olympus FE-280 Digital Camera
This is exactly my problem.
Focus is stuck - could be sand or something in the focus gears. That's the weak spot for these lens. Contact your local Olympus service center or any other camera service center or me at toms.safranovs@gmail.com
Tom
Jul 28, 2009 | Olympus FE-170 Digital Camera
Autofcous and manual focus do not work
excuse me if this is a dumb question but you wouldn't believe the things people do...., but in manual mode are you actually manually trying to move the lens? as manual mode means just that you take hold of the lens and turn it. If it wont turn it sounds like the lens is jammed and needs returning/repairing.
if taking hold of the lens and turning it works for manual mode, take the lens off and clean the gold contacts on both the camera and the lens with a pencil erasor this may bring the auto focus back to life, switch back to auto and try again, if not its most likely the lens but take the body to a canon store and try another lens just to double check the body is ok
drop me a line if i can be of further assistance
best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
FZ-20 "Please turn camera off then on again"
In a lot of smaller point and shoot cameras, there is a separate lens/motor/gear assembly inside that focuses. If this lens won't focus, that is the message you get. The focus lens gears are typically incredibly small, and the tiniest hair, or piece of dirt will jam them. I have not fixed this particular model, but I've cleaned the focus lens gears on countless Casio and Sony models, and gotten them to work again. Try getting to the focus lens and motor, and moving it by hand. You'll find it's likely jamming up somewhere.
Jan 29, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
125 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
