Question about Black & Decker Tools & Hardware - Others
Changinig the belt on a kw 715 is there any adjustment
  • 2,176 Answers
Not that I see by looking at the breakdown for this tool. They don't offer an owners manual for the different types online. If the belt is that loose you might want to take a look at the drive pulleys. Let me know if you need more assistance.
Posted on Mar 13, 2011
How change belt on aerio 2006
the cam or accessory fan belt.?
fan. (guess fan)
same on all cars.
remove or relax (as the case my be ,varies by engine size)
the tensioner.
the remove the belt.
put new belt back just like the old one came off
adjust the tensioner to spec, (depends on engine there)
there are these engines used.
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4
the USA car, has
Models in North America got a larger and more powerful 2.0 L engine with 145 hp (108 kW).
is your car in USA and with 2.0L:?
the tensioner is
the 2.0L is 2 steps (quoted from FSM)
  1. Loosen tensioner by turning the tensioner pulley clockwise.
  2. While holding the tensioner, install belt.
there you go spoon fed, no asking to read the FSM.
hint2, the bolts are metric.
Jul 05, 2015 | 2006 Suzuki Aerio
Part # for drive belt craftsman gt 3000
http www searspartsdirect com model part 3000A 0736 1509200 WL000217 00005... Lawn Mower Variable Speed Belt Part Number 754 0280 GUARANTEED FIT from... Belt 715 0 Part Number 754 0370 GUARANTEED FIT from Sears PartsDirect
Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
Jun 25, 2015 | Craftsman Garden
Fits the driver belt of a B&D planer model KW713/715 in a BD713?
Cannot guiarante it but it seesm like it should.
Oct 14, 2014 | Food Processors
How to change peugeot 306 2005 diesel timing belt
first is what engine is there.
in fact that is the first step on all cars.
1st !
Diesel engines:
1.9L 8V 71 PS (52 kW; 70 hp) I4
1.9L 8V 90 PS (66 kW; 89 hp) Turbocharged I4
1.9L 8V 92 PS (68 kW; 91 hp) Turbocharged I4
the XUD9 engine by PSA.
The XUD9 was available with either SOHC 8-valve or 12-valve heads.
once I identified, the engine
i googled, PSA XUD9 timing belt.
and 1st hit its there.
wrong car, but right engine,
and covers the belt.
see page PDF page 25
id got o Peugeot and buy a real FSM. but that is me.
cutting a fat hog( but is free) see this.
http://www.citroenkerho.fi/xantia/pdf/tekniikka/XUD9.pdf
Jul 15, 2014 | 1995 Peugeot 306
Myopelmariva has a car symbol with the spanner across and it cuts off at 3000 rpm
which engine, most cars have many engines choices.
if the ECU/PCM sets the CAM sensor (CMP) that can be 2 things
loose cam belt, or loose chain, some have belt some have chain.
if the belt is loose, the cam bounces, and the CMP sees that and gets confused, or the sensor is bad. (or just dirty clean it)
RPM limit can be stuck in limphome mode, or lean fuel
or too rich misfire, i see you mech is not so good, here state side any ASE mech would find it fast. (scan tool PIDS)
so enigne which is it. never post engine question to any one, unless you can state the engine, name and number.
let me give and example.
Petrol
  • 1.4 TWINPORT, with 90 PS (66 kW; 89 hp) (from 2005)
  • 1.6 (8v), with 85 PS (63 kW; 84 hp)
  • 1.6 (16v), with 100 PS (74 kW; 99 hp)
  • 1.8, with 125 PS (92 kW; 123 hp)
Both 1.4 and 1.8 are available as flexfuel in Brazil.
Diesel
  • 1.7 CDTI, with 100 PS (74 kW; 99 hp)
Petrol
  • 1.6 TWINPORT 105 PS (77 kW; 104 hp)
  • 1.6 Turbo, with 180 PS (132 kW; 178 hp) (OPC/VXR model only)
Diesel
  • 1.3 CDTI, with 75 PS (55 kW; 74 hp)
more....
it is near impossible to fix any engine not know which one it is.
and 10x on line. we are blind here, but not your mech.
i looks and goes, ahh, z16XSE or...
but your mech, fire him, find a real one and one that has a scan tool., knows how to read live data and how to check the belt for loose or slipped. or just a dirty cmp.
btw those errors mean the CMP is reading wrong. only why is in question, it is reading wrong. for sure.
the CMP can trip for 1 pulse in 10 bad. its a very sensitive test.
with VTT engines more parts to mess cam locations or jog.
variable valve timing, that.
post back your engine. on our cars the VIN tells this tale.
on non usa cars the fire wall chassis tag has engine type clearly stated. read it.
Jun 24, 2014 | 2005 Opel Meriva
Serpentine belt replacement
the cars have more than one engine,
the first job to working on any car, (engine) is to know what is there.
or bad happens. (bad to engine, and buying wrong parts)
i bop over to wiki and...
2.6L 120 hp (89 kW) I4
3.2L 175 hp (130 kW) V6
so which is it?
as you can see and I4 is not a v6, not even in the least same.
i will throw dice, car is USA car, and most cars in USA have too big enigne, and is V6.
so the answer is.
INSTALLING, does that mean you have it removed already or it fell off?
just clue. id hate to print the whole process stated in the FSM.
here are some quotes for you.
Belt tension is maintained by an automatic tensioner. No adjustments are necessary or possible.
there are only 2 systems. auto tension and manual.
we discover that first by just a glance a at the serp, and its friends.
see idlers, see adjustable idlers, that is they move to side when
flexed, bingo , auto tension. if no springs, they are MANUAL.
in this engine, (1)
facing engine, see the crank pulley, and see that tensionor
on the 11pm posision of the crank pulley. that is a spring adjuster
now the text.
Use a wrench to rotate the drive belt tensioner, as shown in the accompanying figure, to remove drive belt.
easy huh, just then the tensioner to loose and bingo ,it is.
and this step 2
Remove any necessary engine covers that are blocking access to the drive belt.
all this was at alldata.com . log in and look.... under access. belts.
Jan 31, 2014 | 2001 Honda Passport
Timing procedure for 2005 suzuki forenza
what engine, most cars have many choices new.. what is yours.
"Displacement or VIN"
cam
or
spark?
btw its really a Daewoo Lacetti from S.Korea makers.
by a real FSM.
or got to alldata.com and read
here is the list of engines
1.4 L 93 bhp (69 kW) Petrol I4
1.6 L 109 bhp (81 kW) Petrol I4
1.8 L 120 bhp (89 kW) Petrol I4
2.0 L 132 bhp (98 kW) Petrol I4
2.0 L 121 bhp (90 kW) Petrol I4
2.0 L 121 bhp (90 kW) Diesel I4
before working on any car, engines. in the USA (where you?)
open hood, look up see that vacuum and smog tag there
and it tells you what engine you have,
than ask questions based on that.
the USA forenza uses the
The US model line features the 2.0 L 4-cylinder E-TEC II made by General Motors, developing a maximum power of 132 horsepower at 5600 rpm.
this is a DOHC engine, 2 cams
and a belt (rubber band engine)
cam timng, im not repeating the 38 steps in the manual or torques/
but the crank cog mark is down aligned with the bottom pan mark
the cams are both at 12pm, aligned with markes on back top pan.
install (cut and past just first 8 steps) 2.0L E-tec II only)
  1. align the timing mark on the crankshaft gear with the notch on the bottom of the rear timing belt cover.
  2. Align the timing marks on the camshaft gears, using the intake gear mark for the intake gear and the exhaust gear mark for the exhaust gear.
  3. Install the timing belt.
  4. Turn the hex-key tab in a clockwise direction to tension the belt. Turn until the pointer aligns with the notch.
  5. Install the automatic tensioner bolt and tighten to 18 ft. lbs. (25 Nm).
  6. Rotate the crankshaft two full turns clockwise using the crankshaft pulley bolt.
  7. Recheck the automatic tensioner pointer.
  8. Install the front timing belt cover.
Nov 27, 2013 | 2005 Suzuki Forenza
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
It appears that the loading belt on my Yamaha CD Changer, Model CDC-715, has stretched and I can't find a replacement other than a site in Australia. Is there a belt cross reference published that gives me...
Hello there! there is a sight smc electronics in which sells belts. simply measure the belt thickness and lenght and subtract 10 percent from lenght for streching and use universal belt. I have the same player so I would order part vcrblto9 . Later gator Jim
Sep 15, 2009 | Audio Players & Recorders
Tools & Hardware - Others Logo
78 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
