Unable to connect sees the wireless set up is fine sets up interface and the just hangs saying "pending" all other laptops no problem it does work if I use a cable connection.Asus eee pc 4g netbook Help please
    Sergeant:
    Champion:
  • 212 Answers
Roter is heatup
Posted on Mar 11, 2011
Unable to obtain valid IP config
Unplug power to ISP modem, till you see it reboot. Test with a cable to establish you can connect directly with ISP modem. If OK, reconnect with wireless modem. You will have to switch between wireless and regular network adapter on laptop for this test.
Use these instructions to test and see IP's.Go to Start > Search > Type cmd and hit enter key.
In Command Shell:
Type ipconfig /all These are your IP settings.
Type ipconfig /release To clear IP settings.
Type ipconfig /renew For new IP settings.
You will need to check NIC drivers in Device Manager if problem persists.
Oct 02, 2012 | Gateway M Computers & Internet
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
My asus Eee pc 4g 701 will not connect wireless
yes! when it comes to wireless networking just make sure that your connection setting are correct just match the settings from your other laptops and do the same to the one you have probles if the persist just do a diognistic check for problems if that doesnt works just hit me back on my link ok!
Mar 26, 2010 | ASUS Eee 4G Notebook
Unable to connect to the internet with a new loptop.
is your wifi broadcasting non-secured signal? try protecting your wireless network with a password. In your case, it might be caused by incompatible protocol like 802.11 a/b/g and if your encryption method is incompatible with your router.
Setup your encryption to WAP not WAP2 in your router interface (http;//192.168.1.1) and configure your Vista to connect to your network using that encryption.
Jul 30, 2009 | U.S. Robotics USR8054 Wireless Router
Failure to connect to wireless network
The WEP key is printed in the bottom side of the router. It is needed only the first time you connect to a router, and the PC "remembers" the settings (i you choose to). Seems like you (or someone) changed the WEP key or you didn't choose to connect automatically before.
Jun 04, 2009 | ASUS Eee 4G Notebook
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
ASUS 901
Ignore setting up the Wireless icon. Use the Network one to setup the Wireless too. As the Wireless icon won't recall the settings. Good luck!
Jan 16, 2009 | ASUS Eee PC 900 Notebook
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wifi
go to your wireless settings, where you can see the connections that your phone can find, hold your stylus on the connection and remove the settings. after that set up a new connection. problem should be solved
May 24, 2008 | HTC Touch P3450 Smartphone
Set up of adsl router
Try resetting the device to the default factory settings. Then see if you can get an IP address, either wireless or ethernet, to configure the router through its web interface.
Nov 18, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
