Question about Microwave Ovens
Microwave starts, sometimes it heats other times does not. GE.
  • 23 Answers
It sounds like you either have a bad connection on the h.v. side or the magnetron is faulty and unable to create an efficient field.the first thing to do is to isolate the power supply from the mains the short out the plug on a metal surface to get rid of any stored energy,then check all the connections on the high voltage side by removing them 1 at a time and tightening the terminal and replacing onto were you removed it .carry on until all terminals have been checked then try it ,if this does not work then you need to replace the magnetron,hope this helps regards les
Posted on Aug 01, 2008
    Problem Solver:
  • 20 Answers
Please try to put stabiliser.
G,K,Mahendran
Ph: 9791055855,india
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
I have a GE profile PEM31SM3SS that heats intermittently. This is the second time it has stopped heating but in the past has started to work again sometimes months later. Is there any fix I can do short of...
do this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 08, 2013 | GE Profile 1.1 Cu. Ft. Mid-Size Microwave...
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
My GE microwave Model #JE1860BH 03 will not heat. It started to arc for a few times then quit heating. Everthing else works. Can you help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is not heating food up. It starts and runs the time but the food is still cold after the time is comlete
Often this is due to a bad door switch located inside behind the area where the door hooks go into the oven. Sometimes, the problem is due to a bad connection or a bad relay on the control board. You can send it back to GE, and it should cost from $30 to $40 dollars to repair.
Dec 07, 2010 | General Electric Microwave Oven
Does not heat up
Bad magnetron tube. Call GE Factory Service 1-800-432-2737 or schedule online www.geappliances.com there is a 5 or 10 year parts warranty on the magnetron tube.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Please Help my GE Microwave produces no heat!!
Most of the time it seems to be the magnetron. The Magnetron is what heats the food, when you remove the magnetron sometimes you will see signs of wear like a black or brown spot on the tube sometimes there is even a hole burned through. A cheap place to find these part is Global Micro Parts in Dallas TX. Usually Magnetrons are about $30 - $45 and shipping is only 7.95 there web site is www.allapplianceparts.com
Oct 26, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
