Question about Olympus Camedia C-7070 Wide Zoom Digital Camera
I turned off my camera and my zoon didn't went back in. now when i turn it back on it says there is a problem with the lens and it doesn't let me use it. what to do?
    Novelist:
  • 147 Answers
This is likely due to a lens error.
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
I keep getting error 99 message and tells me to turn camera off then back on.
No solution on youtube for you? or is that only the Err01 Err 99 for the 17-85 IS lens?
That happens when the zoon lens got stuck.
Nov 02, 2013 | Canon Rebel Cameras
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Turned camera on gives error message to turn off and back on again . No matter how many times we turn off and on it won't clear the message. Took battery out.put back in. Message still there. Also len
Camera was probably dropped. Motorized autofocus lens was probably damaged when dropped. It doesn't get more of a big deal than this. Depending on age of camera, it may be a ''wipe-out.''
Ps... I'm saying ''probably'' dropped because I didn't see it happen, but this is precisely what happens when they are dropped. It doesn't take much of a ''jolt'' to do the damage, and there is usually never any external damage.
Oct 09, 2012 | Cameras
My Sony DSC-S700 froze with the lens open yesterday while I was taking pictures. I took the batteries out and put them back in but it would not turn on. I went home and charged the batteries and it still...
The lens can become bound by grit and dirt, it can be off its tracks, or it can be sitting crooked due to dropping it or rough handling. First make sure you have a fully charged known good batteryc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif in the unit and it is turned off. Plug your Audio/Video cable into the camera. Lay the camera down on its back on a firm smooth surface. Press on the shutter button with one hand and while holding it down turn the camera on. If the lens becomes free, immediately point the lens down toward the floor and use the zoom to zoom it out. Take a soft brush, such as an art brush, and brush around the base of the lens to make sure you have removed any sand, dirt, etc. from the crevice around the lens where it enters the camera body.
If that doesn't free the lens there are a couple of other things you can attempt, but these may damage the camera too. If the camera is going to be tossed in the trash if it doesn't work try these two steps.
1. Take the battery out of the camera. Grasp the camera by the edges of the top and bottom with the lens facing downward. Cup your other hand slightly and smack the face of the camera into the palmc:%5cusers%5charry%5cappdata%5clocal%5ctemp%5cmsohtml1%5c01%5cclip_image001.gif of your cupped hand several times. Reinstall the battery and try the camera.
2. If step 1 didn't work, look closely at the lens seating in the camera. See if the gap around the lens is even all the way around. If it is not, take a thin tool of some sort that will fit into the gap at the narrowest point and softly pry the lens slowly toward the widest part of the gap. If the lens is off the pins, sometimes that will snap it back on. If you hear a small light snap. reinstall the battery and try the lens. If it works, point it face down and run the lens in and out several times using the zoom.
If this doesn't work, and again, ONLY if the camera is going to be trashed if you can not fix it, try prying the the lens out forcefully, but gently. This has worked as a last resort many times. Good luck.
Aug 22, 2012 | Sony Cameras
Dp 1 doesn´t function when the SD-card was returned to the camera
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 27, 2010 | Sigma DP1 Digital Camera
It says "turn the camera off, and on again"
You can try to pull and push on the lens as it starts to see if you can "snap" the lens on track again. More than likely that is what has happened as a result of an impact of some sort. Mostly that is what happened. Be advised that you could damage the camera even more, but it may be worth a try since it is not working anyway.
Jan 21, 2010 | Panasonic DMC-TZ4 Digital Camera
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Aug 25, 2008 | Fuji FinePix F700 Digital Camera
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Olympus Camedia C-7070 Wide Zoom Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
