I have a secondhand Sharp MX2700N copier - do you know how to set the password to protect colour copies - black/white OK as is, just colour protection to use. Thanks.
SOURCE: Sharp AR-5320E Black and White
Sharp AR -5320 Software Download
Posted on Apr 21, 2008
007tech
  • 95 Answers
SOURCE: I have a sharp copier MX2700N with an error code
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Posted on Apr 08, 2009
  • 54 Answers
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Posted on Apr 17, 2009
MalKontent68
  • 748 Answers
SOURCE: Can't open write protected photos on hard drive
I don't know what exactly you mean by "write protected". If by that you mean that they are read-only, you can change that in every file's properties. You can do it one by one, or select a group of files, right click and choose Properties, then uncheck the "Read Only" checkbox, then click OK.
Posted on Dec 03, 2009
zhuismile
  • 77 Answers
SOURCE: How to open password protected PDF files?
You can remove the restriction with Advanced PDF Password Remover 5.0 or PDF Password Recovery 5.0.It can help you remover password intantly.
http://www.advancedpdfconverter.com/products/pdfpasswordremover.html
http://www.recoverlostpassword.com/products/pdfpasswordrecovery.html
Posted on Jun 01, 2010
Line on copies in the same place all of the time sharp mx2700n copier
Replace drum OR main charger OR clean glass OR replace blade d
Feb 11, 2013 | Sharp MX-2700N Color Copier
How do i print with color on this machine?
This machine (Sharp AL 1530CS) is a black and white printer/copier but can Scan (not print) in colour. It only has a black toner so will never print in colour...sorry
http://www.sharp.net.au/cms/products/4011/downloads/AL1530CS_Brochure.pdf
Dec 30, 2011 | Sharp AL-1530CS All-In-One Laser Printer
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
How do i password protect our copies?
you can protect your copier with user code protection just fallow theis steps 1. Press the User Tolls Button 2. Tuch the System Settings 3. Tuch the Keyoperator tools 4. Tuch the User code managment 5. make copier ON & tuch OK 6.Tuch Next and Tuch Addressbook Managment 7. Tuch new program 8. Tuch User Code 9. Enter the number your choise & Tuch the # 10. Tuch the function Eg. Copier & Tuch the OK and Exit the user tools - thanks
Oct 29, 2010 | Gestetner DSm745 Black and White Copier
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
Feb 19, 2009 | Sharp MX-2700N Color Copier
16 people viewed this question
k24674
jasbo
jasbo
