Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Washer will turn on but will not spin
Had a load of clothes that were soaking wet when we opened the door. Tried the spin mode to drain water but would no spin
  • 3 more comments
  • Anonymous Aug 20, 2008
    same thing
  • rnak Sep 06, 2008
    same as above , and also noticed mother board 12a fuse blowing !!! suspect board to be bad . ohmed out motor and other section of electrical could not find any shorts.
  • robina35 Sep 29, 2008
    same problem....whats the solution
  • G8ers1 Oct 07, 2008
    same problem
  • phowell Oct 23, 2008
    same thing...wet load that barely drains and will not spin.  this washer was purchased in the early spring of 2008!
    Genius:
  • 1,028 Answers
Ck door switch had one today tech sheet if needed is behind bottom panel left side wall in envelope if gives test procedure ..switch most likely but still could be control bd issue
Posted on Aug 01, 2008
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is not spinning when it goes into drain mode. The cloths comes out soaking wet. What is my problem
the first thing I would check if the pump is clogged. it also wont spin if the door doesnt lock. other then that the only thing left is the speed control board is bad
Nov 04, 2009 | Kenmore 43142 Front Load Washer
Clothes are sill soaking wet after sin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
RAS6233KQ2 TOP LOAD WASHER WILL NO SPIN CLOTHES
Nov 03, 2008 | Roper RAS6233KQ Top Load Washer
Front load model LTF2940ES3 won't spin
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
May 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
